Please Help on Dana 36 to Dana 44 Rear end Swap...
What parts do I need to convert my Dana 36 to the stronger Dana 44 Rear End.
Is all I need the Dana 44 Batwing and the differential. And what modifications will I need to do if any. Please help me with this.
Thanks, David
:seeya :auto:
PS: Anyone have the parts I need to make the Dana 36 to Dana 44 conversion at a reasonable price not costing me a arm -n- leg...
Thanks, :seeya :auto:
[Modified by 4DJ2NJOY, 3:19 AM 4/22/2004]
Thanks, David
:seeya :auto:
Re: Please Help on Dana 36 to Dana 44 Rear end Swap... (4DJ2NJOY)
I used the Dana 44 driveshaft and C beam. Some people use the stock setup and with the Dana 44 rear and batwing.
I had to transfer my front yoke to the Dana 44 driveshaft.
Vic
Vic
You will need the ZF 6 speed brace, and drive shaft. Use the Yoke from the auto drive shaft. It will bolt directly in.
[Modified by 4DJ2NJOY, 3:17 AM 4/22/2004]
you can usually find the complete assembly for 2k or less. not sure about you, but thats less than my arm and legs worth.
Try ebay, but you'll have a hard time finding a complete converstion, with the 4 parts you need, the pumpkin, batwing, c-beam and driveshaft. I got mine from Zip Corvette. Talk to Justin Abbott, he's their rear end guy. He can set you up with what you need. I don't remember exactly what mine ended up costing, but I believe it was around 2k shipped.
Chris
Chris
