LT1 to LT4 coil switch,
I'm switching to an LT4 coil and I have to change my 2 two pin connectors that go to the coil to a one 3 pin connector. The trouble is, I don't know which of the 4 wires I should use, since the LT4 coil only has 3 pins.
CAN ANYONE HELP ME OUT?????????
Re: LT1 to LT4 coil switch, (vettef6)
Re: LT1 to LT4 coil switch, (Tom Piper)
Why not upgrade to a MSD coil. They are better than the stock LT-4/1 coil. And it is plug and play no splicing wires. They only cost $39. I swapped out my 96 coil it is the dual conetector. Is there a reason you want the LT4 coil???? :thumbs:
Thanks guys for the quick reply.
Tom, the reason for converting to an LT4 coil and driver module is the post you wrote some time ago, but I just couldn’t find it. I also converted to the vacuum vented ‘95 opti spark and now I got the coil and driver module from a friend so it didn’t cost me anything. I would also like to hook up my MSD 6 but that again has different connectors.
Tom, any ideas??
Arnold
Tom, any ideas??
Arnold
