165 changes for a 85 4+3
there are 4 other tables (in tunercat anyway) called TCC lock (and unlock) Vs. %TPS. they control kick down, but may not do much on your 85 since it has a kick down cable (don't know for sure).
easiest thing to do is just compare it to a bin for a 4+3.
for the constants this is what I've been using:
TCC unlock (low gears) 21mph
TCC lock (low gears) 25mph
TCC unlock (high gears) 22mph
TCC lock (high gears) 27mph
TCC unlock prevent/ auto OD engage 103mph
TCC enable coolant temp 50Celcius
min load lock- 0
min load unlock -0
TCC min load limit Hys - 0
TCC min load high/low speed threshold- 0
the RPM kickdowns I have are for a miniram so they won't help you (too high for stock)
