custom cam question
Old Jun 23, 2004 | 12:30 PM
devilfish's Avatar
devilfish
Default custom cam question
I talked to comp cams about my setup, and that I whated a custom grind to it.
This is what they came up with. Looks pretty agressive? It looks awsome when I use it in dd2000. Make 473 CHP
SPEC CARD
ENGINE: LT1 CS ROLLER
GRINDING INSTRUCTIONS 1
"" "" 2
GRIND #: LT1 3194 /3196 HR112+0
SPC INST 1:
SPC INST 2:
J. DIAM: STD INT EXH
VALVE ADJUSTMENT HYD HYD
GROSS VALVE LIFT .583 .586
DURATION @ .006
TAPPET LIFT 281 287
VALVE TIMING OPEN CLOSE
@ .050 INT 7 43
EXH 54 2
SPECS FOR CAM INST. @ 108.0 CENTERLINE
INT EXH
DURATION @ .050 230.00 236.00
LOBE LIFT .389 .391
LOBE SEPARATION 112.0
ROCKER ARM RATIO 1.50 1.50 REQ
Old Jun 23, 2004 | 01:24 PM
SBNova's Avatar
SBNova
Default Re: custom cam question (devilfish)
it looks similiar to what my friend is putting into his carb'd 383. It isnt running yet so I cant tell you how good or bad it is. His is on a 110 cl anyway.
Old Jun 23, 2004 | 01:39 PM
luvmy92's Avatar
luvmy92
that's a lot of lift with 1.5 rockers. I have a cam very similar to that but mine has a 224/230 duration but it using the 3100 series lobes as well (.605/.622" lift with 1.6 rr's). I hope they told you to go with their 977 springs with that cam.
Mike
Old Jun 23, 2004 | 01:56 PM
JAKE's Avatar
JAKE
Their 3100 series lobes are among the most aggressive CompCams offers for a street engine. I'm running one on my intake lobe, but I chose 3300 series lobe for the exhaust to slow the valve down a tad.
Since you're not having any advance ground in the camshaft, you'll need to degree it in and use an offset bushing/key to hit 108.
Jake
[Modified by JAKE, 1:00 PM 6/23/2004]
Old Jun 23, 2004 | 02:18 PM
devilfish's Avatar
devilfish
Default Re: custom cam question (JAKE)
You dont think this cam is to much for my 350 weekend warrior? I dont whant it to over heat at stop and go traffic. And I whant ( with a good tune ) be abel to pass the sniffer test in Sweden.
Jake: good point! Where can I get offset bushing/keys ?
Old Jun 23, 2004 | 02:48 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
That grind will have 30deg of overlap, which is quite a bit for a 350cid. Did you tell CC that it had to pass a sniffer?
Old Jun 23, 2004 | 02:50 PM
devilfish's Avatar
devilfish
Default Re: custom cam question (65Z01)
:bb no... I will mail them now...
Old Jun 23, 2004 | 03:11 PM
LT4BUD's Avatar
LT4BUD
I talked with Competition Cams regarding custom grind and other information.
My experience with them was not what I would call very positive.
As a minimum you should call back and get the advice of a second person there. Based on my experience you rarely will get the same answer twice.
At best you get opinion from their tech line.....at the worst it is actually misinformation
My last conversation was regarding rpm capability of my valve train. Their answer was don't worry about because you would never want to rev above 5800. Per dyno I make max power at 6400. So much for the CompCams tech line...
Old Jun 23, 2004 | 03:21 PM
devilfish's Avatar
devilfish
Default Re: custom cam question (LT4BUD)
thanks for the advice :flag
Old Jun 23, 2004 | 03:24 PM
Red Tornado's Avatar
Red Tornado
I've talked to CC several times in the past, and every time they keep insisting
a 224+ duration cam will suit my needs. I never believed it. That cam, IMHO, is WAY too much for a relatively mildly modded 350cid.
h rocks's Avatar
h rocks
That's an awfully big hyd roller cam for a 350 street motor. (Especially on that has to pass a smog test.) I hope you have someone local that can do your programing. Unless you do, be prepared for a long, unfulfilling experience.
Old Jun 23, 2004 | 03:27 PM
Red Tornado
Default Re: custom cam question (h rocks)
....I hope you have someone local that can do your programing. Unless you do, be prepared for a long, unfulfilling experience.
That too, for sure.
Old Jun 23, 2004 | 03:50 PM
devilfish's Avatar
devilfish
Default Re: custom cam question (bradvette)
I already do my own proms, im ready for that
Perhaps I should say that my sign dont match. Im going to use lt1 intake and AFR 195 heads. Hooker longtubes etc etc
[Modified by devilfish, 9:51 PM 6/23/2004]
Old Jun 23, 2004 | 04:12 PM
Red Tornado
Hmmmm.....with that combo I better now defer to those here who can better address this one
Old Jun 23, 2004 | 05:36 PM
luvmy92's Avatar
luvmy92
All I know is that's a bigger cam than I'm dropping in my 383... and my engine builder has been working on the tune for 3 or 4 days now.
Good luck with it and I hope it works out for you.
Mike
Old Jun 23, 2004 | 11:49 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
They recommended the same cam for my 408 with AFR 210's knowing it would be a street/strip car.
Old Jun 24, 2004 | 01:26 AM
ZD1's Avatar
ZD1
WAAYYY TOO Big cam for a 350 especially one for stop n go traffic. Go with the highest lift 268/272 profile on a 112 deg profile. Go 268/268 on 112 if you have a good exhuast.
If you want to skip the sniffer test go with a 272deg/272deg on a 112 (or 110d sep for more Rpm=LT1/MRII)
To custom cam question
Old Jun 24, 2004 | 02:03 AM
JAKE's Avatar
JAKE
Now that you've asked, YES, YES, YES. I think it's too long in duration for a 350. 218/224 would be much better, but I wouldn't go any higher than 224/230 and I'd put it on 114s.
114s will broaden the torque range, increase the vaccum, smooth the idle, etc.
I've run a ton of simulations using my combination and 230/236 is even too much for my 415 with 11.28 CR. The picture would change, however, if I changed this and changed that, but based on what I'm running I lose a ton of torque and HP over almost the entire RPM band with a 230/236 cam.
I'm pulling 15" of vaccum in neutral and 13" in gear and that's with a 224/230 in a 415 CID engine. The vacuum will be even lower in a 350 which can play havoc with the power brakes and idle quality. Oh, and you can forget about passing emissions; I believe even the HotCam just squeeks by and it's a lot shorter in duration.
A 230/236 will definitely need a PROM re-burn too.
Simplest way (if you don't know how to degree in a cam) is to have the cam ground with 4 degrees of advance already in it. That way, if all else is on spec, all you'd need to do is align the dots.
All the parts places sell bushings - Mr. Gasket, CompCams, Summit Racing, even auto parts stores (here in the US) They're easy to come by.
Hope this helps.
Jake
Old Jun 24, 2004 | 02:09 AM
devilfish's Avatar
devilfish
yeah it helps a lot! I got second thougts about this cam now. I gone back to look on the cc306 or the cc305. Or perhaps keep my hotcam?
Old Jun 24, 2004 | 07:38 AM
luvmy92's Avatar
luvmy92
What do your heads flow? What springs did Comp Cams recommend with that cam?
Mike
