Code 33 need help badly!
Old Jun 30, 2004 | 07:52 AM
88espo's Avatar
88espo
Default Code 33 need help badly!
I have an 88 with just an air foil and screens cut out of the MAS with a K&N filter that is clean. I cleaned entire throttle body and replaced the IAC and the check engine light comes on at no particular time. It hesitates for about a second of two and then is fine but the light comes on. Help please! the code is 33
Old Jun 30, 2004 | 08:45 AM
dwestsr's Avatar
dwestsr
Default Re: Code 33 need help badly! (88espo)
Code 33 is the Maf . The first thing to check is the connection to the MAf. they are prone to corrosion and just getting dirty. Try cleaning the electrical connector under the MAf. Is it possible that you damaged the Maf when you cut out the screen?
If that doesn't do it, you will have to get more trouble shooting info. BTW, the Helms manual has all the trouble shooting info you need for just about anything. Everyone who has a vette needs one, especially if you do your own work.
Old Jun 30, 2004 | 09:23 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I emailed you the diagnostic info and chart.
It from my 86, but should help in diagnosing.
Old Jun 30, 2004 | 01:37 PM
88espo's Avatar
88espo
Default Re: Code 33 need help badly! (dwestsr)
How do I get this repair book? The MAS was not damaged I have tried cleaning the connector and checked all wiring boots.
Sal
Old Jun 30, 2004 | 02:36 PM
Snuffy's Avatar
Snuffy
I too have an 88. I went through the same trials and tribulations as you. I used the Hanes manual and test procedure (as did the GM mechanic at the shop) and it pointed to the MAF and due to the cost I did everything I could to prove it was not the MAF. Connections were cleaned, MAF was cleaned and "tapped", (I believe someone on this forum suggested that) and what it came down to I bought a new MAF and no more problem.
Old Jun 30, 2004 | 07:09 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
This helped me solve a code 33 (MAF) issue on my 88.
Service Bulletin Number: 89-327-6D
Bulletin Sequence Number: 133
Date of Bulletin: 9105
NHTSA Item Number: SB028295
Make: CHEVROLET
Model: CORVETTE
Year: 1988
Component: FUEL:FUEL INJECTION SYSTEM
Summary: INTERMITTENT NO START, LONG CRANK, STALL, OR ENGINE SURGE-BOTH MAF RELAYS(BURN O FF AND BURN OFF CONTROL)SHOULD BE REPLACED-1988/89 CORVETTE DG
The original relays were found to not conduct enough power for the MAF burnoff action to complete. The GM TSB recommendation was to replace the original relays with new GM part #14089936 relays. NAPA can get you 2 new matching relays for less than the dealer (about $11 each) if you give them the GM part #.
Old Jun 30, 2004 | 07:17 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Remove the air filter assembly so that front neck of the MAF is open, have someone start the engine for a minute or so and shut if off while you look into the front of the MAF (use a mirror). If the sensor wires do not glow bright red for two seconds after the engine is shut off, replace the MAF burnoff relay.
If that is OK, replace the MAF power relay.
If the problem persists, find a substitute MAF to check out yours.
BTW, I am in W. Nyack, NY (not far from LF, NJ) and could bring by my AutoXray scanner if necessary to see how the gm/sec data from the MAF looks.
Old Jul 1, 2004 | 01:35 PM
88espo's Avatar
88espo
Where are they located?
Sal
Old Jul 1, 2004 | 03:08 PM
Mike_88Z51's Avatar
Mike_88Z51
Side-by-side under the battery against the firewall. The relay number is "usually" written on the top.
Old Jul 1, 2004 | 03:14 PM
Pete K's Avatar
Pete K
Default Re: Code 33 need help badly! (Mike_88Z51)
When you find the 2 relays try switching the connectors to each relay. If your problen turns into a code 34 you will know it is the relay.
Old Jul 1, 2004 | 07:11 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
You mention you replaced IAC, but is it properly adjusted?
To Code 33 need help badly!
