Help with intermittent Code 16 & dying out
Old Jul 13, 2004 | 08:37 AM
Jim Martley2's Avatar
Jim Martley2
Default Help with intermittent Code 16 & dying out
On our way to Ct on Saturday my wife's 93, with 19,000 miles on it, just cut out while driving 75 mph in the left lane of the Mass Pike. I popped it in neutral and coasted over to the shoulder and tried starting it. It started right up & then died again. This happened a couple more times within 2 minutes and then it stayed running. We continued on our trip and it did this 3 more times within the 90 miles we traveled from Albany to Springfield, MA, where we got off an got onto I-91. It didn't act up again for the rest of the trip to CT nor on the return trip home. I checked the computer last night and there is a Code 16 stored in it. I have the GM service manual for this car and it says it is in the Distributor Ignition System (Low Resolution Pulse) . I find it hard to believe that the Opti is the source of the problems as this car has very low milage. Can anyone help shed some light on what else to check? I realize that an intermittent problem/code is tough to troubleshoot.
Old Jul 14, 2004 | 06:54 AM
Jim Martley2
TTT^^ Anybody??!!!
Old Jul 14, 2004 | 07:52 AM
Steel Blue 91's Avatar
Steel Blue 91
From what I've read, it appears to be an Opti-spark issue (I don't have one of these). I can't be of much help since I have a 91, except to keep it to the top for ya.
Old Jul 14, 2004 | 08:08 AM
Tom Piper's Avatar
Tom Piper
Other than electrical harness connectors, I don't think anything else but a problem in the Opti-Spark would cause this code to set. In a case like this, it is possible that moisture/rust is interfering witht he low-res pulse.
The engine will not run when the low-res pulse is missing completely. But, depending on how many of the low-res pulses are missing when it is intermittent, it may just miss and set a code.
The engine will run at reduced performance when the high-res pulse is missing.
Unfortunately, the Delteq ignition system will not fix your problem -- you need to fix what is causing the low-res pulse failure first.
Tom Piper
Old Jul 14, 2004 | 02:20 PM
BlackbirdZ07's Avatar
BlackbirdZ07
My '92 did exactly the same thing. On a road trip it suddenly died. It ran fine for a while and then died again. It got progressively worse until I had no choice but to stop at a motel for the night. The next day it ran with no problems for 400 miles and got me home. The only code was a code 16.
The problem was the optispark. After having it replaced I've not had any more problems. Interestingly, my optispark also had low mileage. It had been replaced only 20-30,000 miles before this failure, and the failure was not due to a waterpump leak.
Unfortunately, you'll probably have to replace the optispark.
To Help with intermittent Code 16 & dying out
