AAMCO Transmission fluid "power flush"
Haven't heard the specific commercial, but in general all such services are neither necessary nor beneficial. The purpose of a "flush" is ostensibly to remove any contamination present including "old dirty" fluid, makes sense in some cases for the engine but an automatic tranny is a sealed hydraulic unit and if there's any "contamination" present to flush out it means it's already too late and the flush job will most likely just make an existing problem worse. Transmission fluid doesn't get dirty unless it's contaminated by clutch or converter damage. IMHO if the tranny's okay you're better off with a regular fluid drain/replacement (including a new filter and pan gasket) and if it's not a flush job won't help.
The benefit of the "flush" or fluid "exchange" is not about contamination, but to completley change the fluid from old degraded fluid,to new fluid with the proper amount of antifoaming, anti rust, and friction modifiers. The flush machines are desinged to exchange 1 quart old for 1 quart new so that all the fluid is replaced (aprox 90%) not just the 5 quarts in the pan. I am not saying that dropping the pan and changing the filter is no longer neccesary but why would you only change 30% of your engine oil? is your transmission that less important?
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
While I haven't seen any posts in the last few years, there were a rash of posts two or three years ago where people who did this experienced problems because the flush and new fluid broke loose embeded crud which then blocked internal passages
I did the complete flush at 75,000 and now do the pan and filter only at around 30,000
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by PoloGreen1992C4
Has anyone heard the commercials for Aamco's power flush for tranny fluid?
Thoughts??????
Thoughts??????
Just curious, what are they charging for this service? It can a beneficial treatment when warranted but you can do it yourself. I just submitted a DIY method (to tech tips) for tranny flushing but it hasn't appeared yet. I believe it to be a better, much safer method than a power flush. Keep checking, it should be there soon. It is titled "Automatic transmission flush-DIY", or something close to that. I think the flush is warranted when the fluid has been neglected and is very contaminated, as in no longer red (or blue for mine) and smells bad! No automotive fluids last forever and many stated change intervals are way too long in my opinion.
yes very true neglected systems can be held together by crud and flushing them can create problems from washout of buildup.
Personally I recommend the filter every other flush service.
As far as safe the "POWER" is misleading the equipment is run off 12 volts and the pump is actually run of the transmission pumps pressure.
Contrary to your above statement when a car comes in with very dark, burnt, dirty fluid we do not recommend any fluid service untill the transmission is fully checked by a transmission tech, due to the high rate of failure after service.
fluids dont last forever
With everything he says.. Same deal at our shop. Except our machine flushes 16 quarts through the tranny.
"The average flush done in my shop is 85-95 bucks including 12 quarts of fluid. As far as safe the "POWER" is misleading the equipment is run off 12 volts and the pump is actually run of the transmission pumps pressure. Contrary to your above statement when a car comes in with very dark, burnt, dirty fluid we do not recommend any fluid service untill the transmission is fully checked by a transmission tech, due to the high rate of failure after service."
this service with sythetic fluid?
For the 85-130 buck flush job, I doubt it is with synthetic...THe shops around me charge that rate with normal fluid. Shouldn't this be getting flushed with 12-16 qts of synthetic?
Flush
in years.
So still then, a do-it-your selfer has nothing to lose but the price of the fluid. I've heard the failure after fluid change BS throughout my 30+ years in the car and truck repair business but don't know anyone to whom it has actually happened. I say if it did, it was going to go out anyway.
If a flush job seems the right way to go, by all means have it done but do yourself a favor and make sure the filter gets changed at least every 25K-30K miles too (I change mine every year!).
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
I'm a "do it your selfer"
When I flush mine, I drop the pan, change the filter, add four or five new quarts, put it all back together and then do the flush, letting the transmission pump supply the "power"
