Afr Heads
I am little suprised, but not really
A while back someone on this Forum posted photos of a set of AFR heads that showed the casting covered with pot marks (or is it pock marks). Porosity in the casting. AFR exchanged the heads, but that didn't explain away the absence of quality control.
On another board, someone else detailed all the quality control issues he had with a pair of new AFR heads. I'll bet that if you do some checking, you'll find many other examples of the same thing.
For some reason many seem all to eager to forgive AFR for these quality control failures. Having ports that flow like crazy is NO substitute for the problems these heads have been shown to have.
Jake
I put AFR heads and a Crane cam in. As soon as I had it together, I did a leak-down test on a cold engine -- with my LT1, there is no way I am going to get all 8 plugs out while the engine is still warm.
I had about 15% leakage, and I could hear the air hissing from the intake and exhaust. I felt sure it was the valves. Then, I put some oil in the cylinders and turned the engine over by hand before doing another leak-down test. This time my leakage dropped to less than about 7%. Most of my leakage was past the rings, but heard the most noise from the valves.
I then called AFR about the hissing I could hear past the valves, they told me they do not lap valves in because there is no way to get **all** the grinding compound out. He told me, no matter how good you think you are at cleaning it afterwards, there will still be some compound left. Their opinion was it was better to not lap the valves because they would seat-in on their own.
No porosity problems wiht my castings, they looked great.
That was about seven years and 40,000 miles ago, and I have never had the engine apart since.
Tom Piper
That was about seven years and 40,000 miles ago, and I have never had the engine apart since.Tom Piper[/SNIP]
The porosity problem only reared it's ugly head when the owner had the heads surfaced. They "looked" fine out of the box, but once surfaced you could see the casting had what looked like hundreds of little holes in it.
Jake
If you ask AFR, there are no problems with their heads. Ask Mr. Evans what he thinks about their heads, other than the ports.
AFR is on the bottom of my list, when it comes to cylinder heads.
It's those companies that have the financial resources to invest in the latest equipment (and keep it calibrated), highly trained, dedicated personnel and rigid quality control checking/verifying procedures to ensure repeatable, extremely accurately machined products come out of their factory.
Stick the the big names; names you can immediately recognize and can trust.
Jake
The 113 heads can be worked nicely, and they came off a corvette to begin with. There shouldn't be any major geometry issues.
Are you willing to change valve covers ? If you are willing to go with a perimeter valve cover the choices become almost endless.
