Could this be the OPTI
Old Sep 14, 2004 | 09:46 PM
CF6873's Avatar
CF6873
Default Could this be the OPTI
The 94 has not been driven since last Wed. On Sat I installed new radiator(Dewitts aluminum) and tonight I finally got the right size upper hose to complete the job. I filled the cooling system and ran the engine to 200 degrees. I shut it off for about 10 minutes and I was going to take it for a drive. This time it started hard and idled terribly. I could barely get it out of the garage. It pinged and missed badly. I let it sit for about an hour and restarted it and now it runs fine. Any suggestions would be greatly appreciated. It has 75K on it and I don't know if the opti has ever been replaced. Thanks Craig
Old Sep 14, 2004 | 11:37 PM
jabez's Avatar
jabez
It sounds like the Opti but it would be not "running fine" if it was.
Old Sep 14, 2004 | 11:57 PM
bogus's Avatar
bogus
that sounds like a coil wire that is intermitently grounding out.
Old Sep 15, 2004 | 01:04 AM
tjwong's Avatar
tjwong
Did you drible any antifreeze onto the opti during the bleeding of your cooling system? It sounds like it got a little moist or wet and then dried out.
Old Sep 15, 2004 | 07:33 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I'd check the coil and ignition module, too. Both can die with little or no warning and leave you stranded. Trust me...
Old Sep 15, 2004 | 07:38 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
this happened to me
Old Sep 15, 2004 | 07:50 AM
runner140*'s Avatar
runner140*
Default Electricial
This sounds electricial. A ground wire to something? You are right,
also sounds alot like the Opti. You would know if coolent leaked from the reconnection and disconnection of the radiator. Good luck.
Old Sep 15, 2004 | 08:09 PM
CF6873's Avatar
CF6873
Nothing was disconnected in the area of the opti, but I ran my hand under the pump just to make sure and there was no moisture. Tonight I took it for a 1/2 hr drive and it ran great. This is very puzzling. I will check the coil ground. Thanks guys, Craig
Old Sep 15, 2004 | 08:15 PM
James94LT1's Avatar
James94LT1
Yep, thats how my car acted when I had a bad coil wire.
To Could this be the OPTI
