i have a 91 coupe (l98-250hp) 103k miles all stock everything else is in good shape. i want more power so do i upgrade my engine to a 383 or do i trade mine in on a 92 or newer(lt1-300hp). i wont do any of the work on my motor. i will have to pay labor costs for removel and install. what kind of hp will i get from a reg. 383. any info. will be great
thanks jeff
thanks jeff
i did an engine swap on my car after i threw out a rod bearing. i think engine installation around $800, a crate motor from sdpc (scoggin dickey :12498772 ZZ383/425 425 HP 383 Small Block Crate Engine with Aluminum Heads $4,725.00 or 12486041 330HP / 350 GM Performance Parts Crate Engine Assembly $2,389.99. don't forget, you will have to get your computer reprogrammed if you go to bigger cubes(this is actually not that hard).
If you buy that kind of engine your not going to see that advertized power with your stock tpi intake set up. All (most) of the gmpp crates are dyno'ed with a 4 barrel carb on them. Pretty much the only difference in the lt1's and the l-98's are the intake manifold.
You could have your stock engine done up at a local performance shop. Re-build it with a differnt cam shaft, port the cylinder heads, fully port the intake or buy an aftermarket pice, headers and a free flowing exhaust and that will make you alot faster than a stock lt1. You will be keeping your car, that you know won't turn out to be a lemon if you perchased a different car. And you'll have a fully rebuilt motor that could easily pass emmision testings that a built 383 couldn't do. Those are some options. I have a 350c.i. engine in my car. All forged internals, mini-ram intake so on..making alot more power than the gmpp383 would. You can get enough power out of a 350.
If it were me, I would sell the car you have and get one with the LT1. For the amount of $$$, time and energy you are going to spend on an engine swap, you might just as well move into another model year. Unless this is a labor of love. Then you're pretty much screwed . I would get another car because you should be able to re-sell your present car easier if it's in stock form. If you decide to do an engine swap and then decide to sell the car in a few years, you may have more trouble selling it because it doesn't have the original engine. Just my .02.
This is just my opinion but if your willing to buy a newer car, an LT1 for 9 or 10k....i would say screw it...keep your car and get a 396 built and pop in some 3.55 gears and a Vigi 2800 tq converter....i'm sure you would be happy with that
Well it depends on how much power you want:
-a stock LT1 will give you 300chp
-a lightly modified L98 will give over 300chp
-a heavily modified L98 will give over 375chp
-a stroked L98 should put you well over 400chp.
So decide on how much is enough, if you like your current Vette or ready for another one and go for it.
My stock L98 was rated at 240chp and with simple boltons it dynoed at close to 300chp. With heads, cam, headers and modified TPI intake it would top out at about close to 375chp.
I have to challenge you on that statement... the intakes are different, yes, but so are the heads... and the ignition. It's so much different that the heads from the LT1 won't fit on an L98. The waterpump is mucho different, which makes the block different. The LT1 is a reverse flow design, the heads get coolant first, then the block.
Really, about the only thing that the LT1 and the L98 have in common is internal rotating mass and basic block architecture. It is easy enough to bolt an LT1 in place of an L98, the only issue is electronics - and, for that matter, visa-versa.
It is for these reasons GM refers to the LT1 as a Gen II small block. The LS1 and such are Gen III small blocks.
