~~~Whats this hose called~~~
Old 08-01-2001, 10:43 AM
georgehafe
georgehafe's Avatar
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
Hey Guys, car has sprung a leak in the coolant system. It is the hose that goes from the lower part of the throttle body to the top part of the engine. U-shaped about 7-8 inches overall. I need to know what it's called so i can go and order it. Any ideas
Old 08-01-2001, 10:49 AM
Goody
Goody's Avatar
Wouldn't that be a TB coolant hose. Heats up the TB in cold climates to keep blades from freezing closed. Some people will install a bypass kit to remove it for a little HP gain...I don't really see the benefit, but that is MHO. Sorry not to be much more help as I am a LT1 person.
Old 08-01-2001, 10:58 AM
Hendej
Hendej's Avatar
What you want for '85-'88 is-
10108509 Hose, throttle body heater ~$5.85
dyno results? Oh, nevermind.
Old 08-01-2001, 12:47 PM
georgehafe
georgehafe's Avatar
NCM Ambassador
You guys are great, Thanks. It's already on. A little longer then the other but works. Thanks again.
George
To ~~~Whats this hose called~~~
Quick Reply: ~~~Whats this hose called~~~
