K & N cut out
Old Oct 13, 2004 | 02:58 PM
Red_Vette_93's Avatar
Red_Vette_93
Default K & N cut out
My question is when you put in the K & N air filter do you cut out the top piece or the bottom one??
Old Oct 13, 2004 | 03:03 PM
Timmy!'s Avatar
Timmy!
The top piece.
Old Oct 13, 2004 | 03:04 PM
James94LT1's Avatar
James94LT1
the top piece that you screw onto the air intake.
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
What he said...
Old Oct 13, 2004 | 05:54 PM
NightFlight's Avatar
NightFlight
Here's what mine looks ...
redfast's Avatar
redfast
The top one because if you were to cut the bottom you would get non-filtered air into the engine.
Old Oct 13, 2004 | 06:48 PM
88BlackZ-51's Avatar
88BlackZ-51
that looks like mine
Old Oct 13, 2004 | 07:02 PM
Caboboy's Avatar
Caboboy
You may wanna clean that up a bit
Nice job, Z51
Old Oct 14, 2004 | 07:36 AM
Red_Vette_93
Thanks guys, 87Clwy looks great is that a mod you did yourself around the filter?
Old Oct 14, 2004 | 08:18 AM
NightFlight
Thansk and yes, it's a length of plastic wire harness wrap you can get at any car parts store (I got mine at Checkers). I actually got the idea from someone else here on the forum (sorry, can't remember who) when I asked about cutting the lid. I simply slid it on, cut it to length and used a couple of drops of super glue on the inside (at the corners and seam) to hold it in place.
Old Oct 14, 2004 | 08:21 AM
Red_Vette_93
I see you have an 87 I think that is slighly different than my 93 but I should be able to get mine close.
Thanks again
Old Oct 14, 2004 | 09:09 AM
Ghostpilot's Avatar
Ghostpilot
Great Idea with the plastic I'm all over that this weekend!
Old Oct 14, 2004 | 10:38 PM
smokiethegreat's Avatar
smokiethegreat
how much does this mod help?
i was trying to decide what to do on mine and cash is low.
Old Oct 14, 2004 | 11:24 PM
NightFlight
I'm in the process of moving and been too busy to get to a dyno, so I can't give you numbers. I can tell you I can feel a difference since cutting it; she's a little quicker of the light and has a little more power, especially at the lower end. I believe others have said you can 3-5 more HP, but don't quote those numbers, I could be wrong.
Old Oct 15, 2004 | 01:29 AM
R23HTC's Avatar
R23HTC
Start with this:
Remove this:
End up with this:
All there is to it!
Old Oct 15, 2004 | 08:35 AM
runner140*'s Avatar
runner140*
Default A picture is worth.....
A picture is worth a thousand words. Thats what mine looks like. I purchased it open so I could still have my stock one just in case.
Old Oct 15, 2004 | 09:37 AM
NightFlight
Thought about buying an open one, but ended up just cutting mine with a rotozip.
Old Oct 16, 2004 | 07:47 PM
smokiethegreat
thanks for the info 87clwy. any gain i can feel is good enough. looks like i have something else to do this weekend.
thanks to everyone else for the pics, they look great.
To K & N cut out
