people who have had their auto trany rebuilt, come on in here.
I have to rebuild my 90 auto tranny, I was wondering how much ching we are talking about? I heard around the $1500.00 area. Also How long did it take for the shop to complete? What other things should I know about this process?
$1500 sounds about right for your transmission at a shop. should take a week because the parts for a vette are diff than for a regular car that uses your transmission. Also i see your in stratford I am 45 min from you and i rebuild transmissions on the side. I only do bench units so you will have to pull it out yourself and deliver it to me. I can do it for around $1000 depends on what it needs dont know fully till i open it. let me know if your interested.
Having had it done 3 times in 100K miles (lead foot). The Rebuilt Tranny (700R4)from GM costs about $1200 discounted. Then there is labor. Many shops wont touch corvette trans, because of the fact that it is part of the frame, and they have to prop the body up supposedly. Make sure you get a NEW Torque convertor. That is what I break, and then the 3/4 clutch bands go. I have added an extra trans cooler, to the system to prevent the heat buildup. Sudden acceleration breaks the vanes in the stock convertor, I am told.
My tranny was the GM rebuilt unit for around $1500 with a 3 yr 50K mile warranty. It died after 6 weeks and dealer rebuilt that unit and all has been great since then. Seems it was an old shelf unit that didn't have a few of the essential tech bullitens installed. Make sure whomever does the work is aware of them. Good luck.
Bought a '93 and drove it 1300 flawless miles, when I started laying down a smoke trail from a tranny leak. AAMCO rebuilt entire thing including torque convertor at a cost of $1734. After doing it I learned about other options which may well be better.
Cruise-In I Veteran
Cruise-In II Veteran
While I had my engine out for rebuild I pulled the tranny, took it to a shop in town and they went through it for only $420.00. They pulled it apart, inspected everything and said that there was nothing wrong with it and only replaced all seals. I only did it due to the fact that my rebuilt engine was going to be a bit more muscular 350/350 and I wanted to make sure it would not fail after I put the engine back in. The shop gave me an initial estimate for major fixing of $800.00. They even loaned me a low rider tranny jack to put it back in with.
Funny how a topic seems to ''be'' there when you have a similiar problem.
Yesterday Hubby was coming home from work in the '94..and he came to a stop sign...he stopped and when he tried to go the car was acting like it was in neutral????
Took him a bit to finally get it in a gear (D) but as it sits right now have NO reverse or over drive...I fear this is NOT good. There was no warning atall...no slipping...no grinding sound....nuthin.
Did check the fluid...it is full.
was thinking maybe the filter???
Anyone with any idea??
Mine cost around 1400.00 and the the shop had to do it over about 4 times because they kept screwing it up.. after threating to take further action the owner of the shop finally did it right..
Stay away from American Transmission on University in Jacksonville, Fl. !!!!!
Just had the tranny rebuilt in my '85. Cost was $1600 + fluid + tax. I had the yoke on the drive shaft replaced due to wear. The transmission shop did excellent work and includes 1 year warranty. Be sure and check the exhaust system because it is removed to get the tranny out. Mine had a minor leak which the shop fixed after I test drove the car.
The old tranny went away after making a right turn. No warning,no noise,no go!!!
Has anyone had any dealings with Fourth Gear out of Apopca, FL. They had been involved with a couple of Vette or Vette Fever pictorials about 700R4 rebuilds. I've talked to them and I think their price was about $750 trans delivered to them. Freight was another $150 (air freight). Sounds like they add later front pump and a few other little upgrades. Anyone??
Thanks,
Thanks,
For those of you who only changed out / rebuilt your tranny, did you notice a lot more power? I know auto's zap some power just wonder if one that is going out will zap even more out of it.
My car seems like it should have more umph, and im thinking the lost umph might be in a worn out tranny, but it drives fine, and you guys said yours did until it just up and died. Just trying to chase down an idea.
$1200.00 at the site below. I know it is to far away but their site has good information on 700R4's www.bowtieoverdrives.com
Originally Posted by LakotasRose:
[B
[B
[/B][/color]
[/B][/color]
Bottom line] $1786 rebuild including R&R. Took a week.
Originally Posted by Mike263:
[B
[B
Mine did a simialr thing last year. Stopped at red light. When the light changed trannie acted like it was in neutral at first. Finally took off with only first an second gear. Absolutely no advanced warning.
[/B][/color]
[/B][/color]
My 92 had a new Jasper trans put in by the previous owner. It came from Jasper Engines and Trans with a "performance rebuild" that included a 10% lower first gear for better off-line performance.I don't know the current price, but you can call for details at 1-800-827-7455. I don't work for Jasper. In fact my brother works for their competition, ATK.I just am very pleased with the performance of my tranny.
What a jinx, After responding to this topic, my trans goes out like it heard me or something. Anyone heard about a bullet proof trans from level ten? $2400. I am walking agin, dammit! Grrrr. The new powerful engine must be responsible.
Cruise-In I Veteran
I got your email, I don't have any good transmissions in at the moment but I'm looking around for you! $1,500 is way too much from what I usually would charge, but you're in a different area. I can probably get it a lot less with the local transmission man here in NC. But shipping may be a hassle for you, and a rebuilt unit just sent outright to you may be feasible. Like I said, I will see what I can do!
Good luck, sorry to hear of your troubles....
C.J.
C.J.
