Aluminum valve covers on an LT1
I've been looking at some aftermarket valve covers and noticed that most of them say "87 - up SBC center bolt.......Not for LT1/LT4" Anybody know what the difference is?
I think it is the height/profile. Some of them may work but hit or rub where the alternator sits. Don't know for sure, but this is my best guess. I know the alternator is a problem area for some valve covers.
We have a cast aluminum valve cover (the tall style) available. It has a polished strip on the top. This valve cover is only available with a stud girdle (which it comes with). The cover is "tall" to clear the girdle, as well as notched to clear the alternator. The cover actually attaches to the stud girdle through a custom bolt setup.
These are not in stock, but made to order. This is the only drop in aluminum valve cover I am aware of though.
Thanks Chris, but I'm looking for a stock replacement short valve cover (Aluminum). Several companies make them - Edelbrock, Billet Specialties, Moroso...they just say "Not for LT1/LT4". I was just wondering if it was clearance on the Alt bracket or bolt pattern or dimension or what?
They need to be centerbolt - but aside from that if they are a "short" cover they should clear the alternator - or you might need to clearance them slightly with a ball-peen hammer. I have a set of chrome ones, but can't recall any aluminum ones off the top of my head. I will check around though.
I have a buddy that has a set like the second picture. He still has them sitting on a shelf because he could not get them to work with 1.6 roller rockers (they hit the underside). They have already been clearanced for the alternator and are in new condition. If you are still using 1.5 rockers, I can put you in touch with him. You could probably work a pretty fair deal for them. Email me if so.
Originally Posted by 95Aqua
I've been looking at some aftermarket valve covers and noticed that most of them say "87 - up SBC center bolt.......Not for LT1/LT4" Anybody know what the difference is?[/color]
Jeff
