Early C4 to Late C4 interior kit??
St. Jude Donor '03-'04-'05-'06-'07'-08
I remember a while ago seeing info on this upgrade kit... with my recent fire, (see http://www.corvetteforum.cc/ubb/Foru...L/023759.html) I thought I'd install new interior. Any help w/ locating a kit like this would be awesome! Thanks
Jeff,
Check with Mid America (www.madvet.com). They had a kit with Leather Seat Covers, Carpet, and door panels. I forgot what they cost. But it was cheaper than buying each separately. I'm assuming you also need the dash parts too huh? You can give them a call and see what they can do for you. Also, some of the companies will give you a discount for buying lots of restoration parts at one time.
Another option is the junkyard/salvage yard.
-Tim (mariah@hawaii.rr.com)
Sounds like he wants to go to the 90 later interior..
I am doing that this winter.. I have not found a kit but I am buying the complete dash from a 93 for my vette.. Although I will use 94-96 white lettered controls
[/color]
[/color]
Originally Posted by jackyl
Jeff, that is exactly what i'm wanting. Will the interior fit in there? I mean like door panels ect.? I'm wanting to put in a all 90 and later interior. Any info you've done on research would help a ton!! I need to get it all together ASAP so they can get the fire damage fixed. Thanx.[/color]
Jackyl,
You have mail..
As for the conversion.. depending on how much you want to swap is how you convert it..
I am either swapping the dash and using a 7730 ecm or swapping the engine harness too and using a 7727 ECM
You have mail..
