Z-51, Z-52...and so on ?
Old 07-26-2001, 12:52 PM
apollo30346
apollo30346's Avatar
How can I determine if my car would be equipped with these options or which one might be on car. What are some signs or what to look for..number's, markings, etc...
Thanks in advance for the help..
Old 07-26-2001, 01:07 PM
scorp508
scorp508's Avatar
For an '88 the easiest thing to do would be to open your center console and look for the RPO codes on the tag that is affixed under there. Just make sure that the VIN on it matches your car in case it has been replaced at some point.
Oh yeah, and your sig shows that you have the 17" wheels that came with Z51 and Z52 also. So you've got one of htem as long as those are what came on it originally.
[This message has been edited by scorp508 (edited 07-26-2001).]
Old 07-26-2001, 11:42 PM
apollo30346
thanks I will look at that.. What should I look for or will it tell me?
Yeah, I have the 17's, mine still had the original tires on it still when I bought it... Not any more though... they were just a little hard and old....
Old 07-27-2001, 12:23 AM
scorp508
scorp508's Avatar
You'll see Z51 or Z52 stamped right on there with a bunch of other ones.
Old 07-28-2001, 12:04 AM
apollo30346
thanks I will take a look and post it....
Old 07-30-2001, 10:46 AM
apollo30346
Well, I have the Z-52 option..
Now,
can someone explain this option to me and what the difference is over not having the option.
Old 07-30-2001, 12:06 PM
ZylaRace
ZylaRace's Avatar
Z51 PACKAGE, PERFORMANCE HANDLING
Z52 MERCHANDISED PKG, SPORT HANDLING
(Sorry, don't have the detailed spec's.)
Old 07-30-2001, 01:19 PM
apollo30346
Thanks,
Does anyone have the specs on the Z-52?
Old 08-03-2001, 11:51 AM
apollo30346
Default Re: (apollo30346)
Can anyone explain what the Z-52 is and what it does for my car.... I know thanks to you guys here it is the merchandised/ sport handling pkg.
What is he difference over one without and what are the parts etc...
How could I research the things myself without having to bud you guys all the time..
Thanks again for the help....
:confused: :confused:
Old 08-03-2001, 12:52 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
apollo30346, our Z52 option package includes:
..B4P-radiator boost fan (aux front "pusher" fan).
..FG3-Delco-Bilstein shocks.
..KC4-engine oil cooler.
..17x9.5 wheels.
..quick ratio steering.
Old 08-04-2001, 09:41 AM
apollo30346
Default Re: (65Z01)
Thanks for the info.... The only thing I don't see is the aux fan set up in the front for some reason..... Maybe I just did not look good enough...
To Z-51, Z-52...and so on ?
Quick Reply: Z-51, Z-52...and so on ?
