What type of grease on headlight motor gears?
07-27-2001, 08:31 PM
In process of replacing both the larg and small gear in the headlight motors of my 86. What type of grease do I use on the new gears?
thans
07-28-2001, 12:30 AM
Thats a good question... I don't remember!!! But! Corvette Fever or Vette did do a report on rebuilding the drive systems on the headlites, as such, I am sure they recommend a lube...
If I can put my hands on the issue, I will check. I was within the last year. check their respective sites...
07-28-2001, 03:10 AM
White lithium works fine.
07-28-2001, 03:47 AM
Cruise-In II Veteran
i lightly used synthetic wheel bearing grease
07-28-2001, 06:20 AM
Wheel bearing grease is a bit too thick to use on there. White Lithium is what was in there from the general.
07-28-2001, 10:47 AM
I'll try the white lithium.
07-28-2001, 11:12 AM
I know that Some use high temp grease, But White Lithium should work well.
07-28-2001, 09:00 PM
White Lithium does the job.
07-28-2001, 10:31 PM
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Like they said White Lithium. Thats what I used when I replaced the bushings on one of mine.
