Valve train done, just start it up or....?
Cruise-In II Veteran
New studs, guides, rockers and pushrods are in. Just finished setting lash to 3/4-turn and the valve covers are about to go on.
The plan is to pull the injrctor fuse and the ignition (dist) fuse, reconnect the battery and crank it over a copla times to see if all sounds ok before firing her up.
Does this sound like a viable plan to detect any problems before damage is done or should I just install the injecotr harness, plugs and wires and light the fire??
You might want to get a special tool that lets you spin up the oil pump with a drill. It will help fill the lifters and such.
I know you do this on a fresh rebuild. Not sure how difficult it is to do with the engine in the car.
Jay
92 LT1
Jay
92 LT1
I know it's std for when cam, lifters, etc. are out, but thought just cranking without ignition would get the oil upstairs and let me do an audible check too.
BTW, I used Comp Cams light assembly lube on the pushrod ends, rocker indents and valve old ends.
Im sorta curious about this as Im about a week away from getting the motor back and finishing my rebuild with fresh pushrods etc.
What all should be done again?
Paul
Paul
I know that with an engine rebuild you pull the dist and spin up the oil pump with a drill and a rod to engage the pump.
Assembly lube isn't necessary on rolling parts, only on sliding parts. Since I installed ProMagnum full roller rockers the only places I need assembly lube was on the new pushrod ends and in the pocket in the rockers. Since I raad that the roller tip actually slides across the valve tip, I put some assembly lube on the old valve tips too. Oops I foregot to put some on the sides of the pushrod guide plates; hope I don't need to remove those valve covers again!
