95 Oil Change Light, need to turn it off
Old 07-29-2001, 04:32 AM
ricks95coupe
ricks95coupe's Avatar
I've got a 95 coupe. I change my oil every 3,000 miles. Today, about 2,000 miles into my oil change this light comes on. How do I turn it off?
Any help would be appreciated.
Thanks, Rick
Old 07-29-2001, 10:06 AM
Admiral Fairway
Admiral Fairway's Avatar
Here is the procedure for a '94 I think it is the same for a '95.
Turning off the change oil light
1) Turn the ignition "ON", but do start the engine.
2) Press the "ENG/MET"button and release, then, within 5 seconds, press it again.
3) Within 5 seconds of step 2, press and hold the "GAUGES" button. While the button is held, the "change oil" indicator will flash.
4) Continue holding the "GAUGES" button until the "change oil" indicator stops flashing and goes out, indicating successful completion of the reset cycle. This should take about 10 seconds. If it does not successfully reset, turn the ignition "OFF" and repeat the procedure from step 1.
Old 07-31-2001, 08:33 AM
ricks95coupe
Thanks for the info. I'll try it this evening. I appreciate it.
Rick
To 95 Oil Change Light, need to turn it off
Quick Reply: 95 Oil Change Light, need to turn it off
