Which Coil to use for an LT1?
Old 07-30-2001, 07:43 PM
Timmy!
Timmy!'s Avatar
While pulling the engine, I noticed that the coil isn't looking too pretty.
Any recommendations on which one to replace it with?
MSD, ACCELL.
Anyone have good or bad experiences with a particular one? ALso, post a part number if you know it.
Old 07-30-2001, 11:59 PM
Dr. Doom
Dr. Doom's Avatar
I have used both. No complaints with either. I currently have the MSD coil. The Accel was still working fine when I removed it. I changed it to the MSD when I installed the MSD 6AL ignition. Probably would've been fine, but I just had to have a "matching" system. Sorry, I don't have the part numbers handy for them(actually the Accel coil came as a package with the 300+ ignition- which lasted about 3 months), but Jegs or Summit should have them if you have a catatlog.
Old 07-31-2001, 01:16 AM
Rich_01659
Rich_01659's Avatar
Just installed a MSD coil last month . it is listed as a GM EXTERNAL HEI COIL, HI PERFORMANCE. part number 8226
so far no complaints
Old 07-31-2001, 03:46 AM
40th_roadster
40th_roadster's Avatar
MSD.
Old 07-31-2001, 09:54 AM
Nathan Plemons
Nathan Plemons's Avatar
I've got an MSD. Better than stock? Who knows. I just replaced my wires with MSD and put in NGK TR55 plugs while I was at it. Eventually I'll add an MSD 6al, so it'll all match. The aftermarket coils are probably all pretty much the same.
Old 07-31-2001, 02:33 PM
Thumper
Thumper's Avatar
Cruise-In II Veteran
I just ordered an Accel Super coil, part # ACC-140011. There probably all pretty much the same but I didn't want a red coil under my hood, I preferred the yellow. Haven't got it yet so I don't know how well it works.
Old 07-31-2001, 02:41 PM
Timmy!
Timmy!'s Avatar
I ordered the MSD coil and some MSD plug wires from Jegs.
Thanks to all for the recommendations.
Tim
Old 07-31-2001, 02:56 PM
SPD DMN
SPD DMN's Avatar
Cruise-In I Veteran
I've run the MSD 8226 for almost 2 years without problems.
To Which Coil to use for an LT1?
Quick Reply: Which Coil to use for an LT1?
