Bleeding the Brakes ABS module
I have a new master cylinder in my hands. I'm going to bench bleed it with the little kit... The next thing is to bleed all four wheels with the furthest one first.
I've heard of a requirement to bleed the ABS modulator first. It's behind the driver seat from the bottom.
Is this really required? I look under the car and there's a tub with an aluminum plate and a bunch of bolts. All the hydraulic lines go in there first.
Can I just bleed the calipers or do I have to take this tub apart to get to the ABS thingy?
Cruise-In II Veteran
My '88 Shop Manual says to bleed the MC first and then each caliper in the sequence of RR, LR, RF, LF. There is no mention of bleeding the ABS.
I have a bad MC and will (hopefully) be picking up the replacement Mon AM so I'll find out how this plan works.
Found it in the Helms manual. I opened up the tub behind the driver seat - and there it was clear as day.
There is a bleeding fitting right on the side....Piece of cake.
I always thought that screw was for "factory use" only - the modulator valves are open with the engine off and bleeding the calipers is all that is needed - at least that's what the literature says.
Received 3,043 Likes
St. Jude Donor '05
Well, here's the scoop: I tried to bleed the ABS unit... Bleeder valve, tubing - the whole nine yards.
With the foot on the brake - nothing flowed. With the foot off the brake, fluid would slowly drool out like a gravity bleed. Tried several times - ended up loosening the bleeder valve by about 4 turns before giving up.
Then I bled the rest of the system. RR, LR, RF, LF. Then one more cycle through the wheels to make sure.
In the end - took the car for a spin (oh yea - there's a new bias spring in the master cylinder too)
What a difference!
ahhhhhh to be able to stop is a nice feeling.
What a difference!
mitchcole glad you got her under control, and now I know how to bleed them for sure.
cuisinartvette if they provide the correct MC and if I don't have to bleed the rears (never been off) it should be cake...but is it ever that way.
