Ok Here's My Take On The Lt4 Knock Module
Old 11-17-2004, 03:20 PM
1c44ya
1c44ya's Avatar
Default Ok Here's My Take On The Lt4 Knock Module
Ok , . . here is my take on the LT4 knock module. I was'nt sure that it was even nessasary, but after reading up on it and getting feed back from some guys on the forum, i decided to get it and see if it made any sort of difference. First of all,. .i have headers and 1.6:1 RR's and a chambered straight thru exaust. I'm listing these mods only because these are the ones that might produce false knock, and thus retard the timming. The LT1 knock module is super sensitive and could pick these things up as knock, and thus retard timming.
I did'nt think i had a problem . Putting the LT4 module in was a snap. After the install i left my neg battery cable disconnected for about 20 mins , then reconnected it . I fired up my courious LT1, and it seem to gasp , and then sigh, as if it were telling me "thats what i've been looking for"!!!
My idle became very smooth and steady. So after warming up, i took it for a little drive. I instantly noticed the sharp, crisp throttle response, and although i dont have any track times to boast to u, it sure feels to me that my car is pulling harder all the way thru the rpm band. A really noticeable pull right after a shift. Almost felt like i had some boost from a turbo.!! . . . . ok maybe thats alittle exageration, but i'm sure u get the idea. All and all , i'm very glad i did it. And just think ,. . i would not have ever thought i needed it , if u guys had not brought the subject to the forum.
Thanks guys!!
Old 11-17-2004, 03:33 PM
TankerVette
TankerVette's Avatar
umm...
I put one in after my mods, still getting knock counts like crazy...
Sure hope it isn't really knock, running Chevron 92...
Old 11-17-2004, 03:37 PM
1c44ya
1c44ya's Avatar
maybe u have something else going on in that motor
Old 11-17-2004, 03:53 PM
ztrips
ztrips's Avatar
Where did you get the knock module? Cost? Install process?
I'm thinking about doing the same...
Old 11-17-2004, 04:03 PM
1c44ya
1c44ya's Avatar
i got it thru a chevy dealer and it cost $60 Installation is easy , disconnect your neg battery cable , undo the 2 screws that hold your PCM to it's tray. flip the PCM over and use "T-20" TORK screw driver to undo the 2 screws at the knock module, pry the lid up, reach in and push the tabs and remove the old sensor. snap the new one in , and close everything back up , leave battery cable disconnected for about 15-20 min. hook up and start car
Old 11-17-2004, 04:14 PM
mikey whipreck
mikey whipreck's Avatar
Didn't realize later C4's had a problem with that...
I know my early C4 is plagued by false knock.
I ordered an upgraded ESC module (from gmpartsdirect for about the same price) and will be putting it in this week...
I hope for results similar to yours.
Old 11-17-2004, 04:15 PM
1c44ya
1c44ya's Avatar
what yr is your car?
Old 11-17-2004, 04:20 PM
mikey whipreck
if you mean me,
mine is a 1985 'l98
I am sure I am getting false knock. The sensor and wiring is new.
I'm hoping for a big difference from an upgraded esc... I shall see.
Old 11-17-2004, 04:22 PM
ToyC4
ToyC4's Avatar
St. Jude Donor '05
I got my LT4 knock module from Chris at Superior Chevrolet and I think it was only $25-30 ?
Old 11-17-2004, 04:25 PM
1c44ya
1c44ya's Avatar
well u got a deal , but chevy parts list them at $60.86
Old 11-17-2004, 05:08 PM
ToyC4
ToyC4's Avatar
St. Jude Donor '05
yep for anyone needing good prices on GM parts Superior Chevrolet is the hook up. Call Chris 1-800-728-8267 and tell him you're with corvetteforum he sells everything at 10% over cost.
Old 11-17-2004, 05:16 PM
mikey whipreck
check gmpartsdirect as well...
prices seem about the same, except the gmparts site will gouge you on S&H.
Old 11-17-2004, 07:40 PM
MYCoupe
MYCoupe's Avatar
Anybody have the part #?
Old 11-17-2004, 08:07 PM
Shore
Shore's Avatar
Would this be a good idea on 100k 92?..I have a good hook-up at the local chebby....I do alot of work for them.
Old 11-17-2004, 08:40 PM
FD2BLK
FD2BLK's Avatar
Originally Posted by TankerVette
umm...
What is your knock sensor TQ to? I have found if it is to tight it will cause false knock if thereis any noise what so ever (14 ft pnds is correct TQ) I have a 383 1.6 R/Rs, LT headers, no cats, single mass and magna flows and zero knock count.
Old 11-17-2004, 08:52 PM
TankerVette
...Never have changed them ... Tried to get 'em out once (during a coolant flush), but no love...
I think that renewing them is the next thing I'm gonna have to try, though I guess I will have to use the brute force approach...
She's got 81,000 miles...
Old 11-17-2004, 09:02 PM
Red Rocket
Red Rocket's Avatar
Didn't have much luck with the LT4 knock module in my 396. Finally turned off the Knock sensors in the PCM.
To Ok Here's My Take On The Lt4 Knock Module
Old 11-17-2004, 11:00 PM
Lone Ranger
Lone Ranger's Avatar
Same here. I recently put mine back in just for the hell of it. Can't hurt. Beats leaving it on shelf I guess...
Old 11-17-2004, 11:04 PM
Lone Ranger
Anyone know if it hurts to loosen it and re-torque each one to spec of 14 lb-ft? Or will that make it leak coolant loosening it and re-torqueing?
Old 11-17-2004, 11:31 PM
FD2BLK
FD2BLK's Avatar
I would think as long as the sensor did not get dammaged then try it. Worst case you will have to pull it and add some RTV before reinstalation (BTW my last motor had a false knock problem because I over tightened the knock sensors, I checked the spec before installing replacments and set the new onew to 14# and never had another knock problem)
Quick Reply: Ok Here's My Take On The Lt4 Knock Module
