Here is my issue. I am debating Stainless Steel header (1 5/8) over the EM mild steel headers (1 3/4). I have and will be using the Corsa cat back system. Currently, my engine build is fairly stock, however in the future (not near) I would like to go to a stroker motor. I am running a 6 speed, so the Stainless Works headers will fit my car.
Pro's for Stainless:
Never rust
Function well on a stock to mildly mod vette
Cons for Stainless:
If I ever upgrade to a stroker engine I will need to repurchase headers.
Pro's EM Mild Steel:
Coated
Function well on a stock and Mod vette
Cons EM Mild Steel:
Some say you lose torque on a stock engine
Will evidentially need to recoat. (What is the average life of the coating?)
So with all this said, on my current configuration would you get the Stainless headers or the EM? I like the idea of no rust and longevity with the stainless; however I may need to get over it for performance. Forum thoughts please.
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
Originally Posted by mothersworry
Cons for Stainless:
Coated
Cons EM Mild Steel:
The SS headers will work fine on a modded motor... why would you think they wouldn't? I've seen coated headers last 10 years with no problems... besides... you still want to coat stainless headers. I had a set of SLP's made of 409 stainless and it lost it's beautiful shine after the heat hit it.
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
1 5/8th headers are also large enough for 383 stroker engines too. Ski and Corky didn't need them until way up there in cubic inches. You can also get a 1 5/8 from EM if you want them.
Also I am happy with my 1 3/4 Hookers on my basiclly stock motor. There is no big torque loss but from what CFI-EFI says there is some torque to be gained by sticking with the 1 5/8ths. My wallet just didn't allow for a quality set of 1 5/8th so I went with the Hookers.
Reason: sig pic too large
But they also don't turn extremely high RPM's either. Essentially there is no blanket answer. Personally I belive that 1 3/4 is the way to go from the results that I have seen first hand, others will argue.
Nobody has ever done back to back dyno / track testing with 1 5/8 vs 1 3/4 headers on these cars so it's really impossible to tell anything with any certainty.
These numbers are just rough estimates because they assume 100% volumetric efficiency of the motor, but take a look just the same.
A 434 turning 5000 RPM's would flow 627 CFM
A 350 turning 6500 RPM's would flow 657 CFM
A 383 turning 7000 RPM's would flow 775 CFM
So you can see it's more complicated than just a simple displacement question. A large displacement low RPM motor may well require a smaller header size than a smaller displacement high RPM motor. Intake / heads / cams all play a role.
EM makes a nice system that hooks right up to the Corsa cat back. I have this setup and I must say, this was the easiest set of headers I have ever installed. Beautiful.
I pretty well agree with all that has been posted in answer to the question, so far. You MAY be able to tune a stroker to take advantage of the larger tubed headers at high rpms. For 1/4 mile only, blasting out of the hole with a 5000 rpm stall and shifting somewhere near 8000 rpms, you might get an advantage with bigger headers. If you're going to be building something you intend to drive on the street very often, the 1 5/8ths" tubes will give you more smiles per mile than an all out race set up. To repeat what I've said in the past. The 1 3/4" headers may not cost you torque from what you have now, but you will sacrifice the GAIN in torque you'll get with the 1 5/8ths" headers. The 1 5/8ths" headers will NOT cost you in top end power on any 400 cid or less engine set up for frequent street use.
St. Jude Donor '03
Yeah, don't get me wrong I really think 1 3/4 is fine. Heck thats what I got. I just was pointing out that I don't think it is a big deal whichever way he goes. I think alot of this Header stuff is much ado about nada.
WE all hate to buy the same item twice because we got the wrong thing the first time. However, you said the bigger engine is not in the near future. So that is one count in favor of the smaller mild steel. Many of our current expectations change over time, so you may not even get to the larger engine. For example, you might sell the car for something else instead.
Secondly, the smaller headers will work well with a larger anyway. I sometimes think we all can get caught up searching for the last HP or ft/lb of torque. You can always change them in the future if it becomes a big deal.
I'd go with the best header for your current expectations rather than a "maybe". (Spoken by a guy who has bought the same item twice several times) It turns out to be an annoyance more than anything else. It also gives one "character"
Yup, just making some observations.
The numbers come from the following calculations:
For one revolution only 4 cylinders would be on the intake stroke, thus the effective displacement is only half of the total displacement, or displacement per revolution. Multiply the displacement per revolution by RPM to get CFM.
Again these numbers assume 100% airflow into and out of othe engine, actual numbers will be significantly smaller. Interesting about those 1000 CFM throttle bodies on 350 motors huh?
Some day I will dig into this topic so I can make an intelligent observation........but for now I will post a question out of a lot of ignorance...
Just what do CFM ratings of various devices really mean.....so if we put a 1000cfm throttle body into an intake manifold that flows ???? into heads that flow????, all these thru a MAF that flows ????,
what do we really end up with???
My point is that flow ratings come about with a pressure drop of some sort, so if we do "oversize" each component, don't we end with a system that flows better???? thus more power potential......
I am still pretty convinced that an "oversized" throttle body won't hurt anything and will result in some kind of gain....plus cost of 58mm=costof 52mm so why not??? Same with oversized MAF or air cleaner system if they are available...
Back to the original post, I seriously question that 1-5/8 vs 1-3/4 is really a BIG deal........I'll get my new EM's on soon and see what I gain....but I'll never know what the 1-5/8 would have done...but I don't plan on loosing any sleep over it...
Is is possible that if they are using the 1 3/4 mild steel tube that the I.D. is actually less because the mild steel tube needs to be thicker than the stainless one due to heat?
What do you guys think, worthy of another thread?? I think so, started off with the #'s provided by Nathan as a reference. I have a few observations and would like to know if they are misguided
On thread topic, I think CFI makes a good point about not losing vs gaining and, given a streetable combo, could anyone tell the difference? I would think certainly not. The ultimate decision may be better made based on quality, fitment and price.
I'd like a lot of dicussion on this topic. My interest is at what levels Cylinder head intake flow become too small for the size of the engine. Specifically, would a ported AFR 195 (flows about like an unported AFR 210) be able to produce good "streetable power" on a 415-427 cu inch motor? By streetable power, I mean around 500 hp at 5,500 to 6,000 rpm, assuming LPE 219 cam and SR induction. I am pretty sure the induction and cam are adequate for that power level, but do not know about the heads . I want to keep EO compliant heads and the AFR 195 do that.
