R & R Rack & Pinion.
Old 01-24-2005, 12:50 PM
CAJUN C4
CAJUN C4's Avatar
Default R & R Rack & Pinion.
Anyone Replace their Rack & Pinion? Shop quoted me 3.5 Hrs and $228.00. Is it Very Difficult?
Thanx Guys
Old 01-24-2005, 01:19 PM
HiRiser
HiRiser's Avatar
It's not easy, if I could have paid ~$200 labor, I would have
Old 01-24-2005, 01:23 PM
CFI-EFI
CFI-EFI's Avatar
I thought it was pretty straight forward and fairly easy. No big deal, here.
RACE ON!!!
Old 01-24-2005, 05:03 PM
Strick
Strick's Avatar
Setting up the proper pinion depth and ring mess takes some skill and knowledge. If you don't get it right standby for some whining gears and short life.
Old 01-24-2005, 05:14 PM
USAsOnlyWay
USAsOnlyWay's Avatar
Uhh, thats the rear end buddy
The rack and pinion is steering, ring and pinion is differential
From what I have read, it seems pretty easy, I'll be putting in a Z51 quick ratio rack later this summer.
Look here:
http://forums.corvetteforum.com/showthread.php?t=999128
Old 01-24-2005, 05:57 PM
19corvette91
19corvette91's Avatar
Old 01-24-2005, 11:51 PM
USAsOnlyWay
Originally Posted by 1991camaro
Uhh am I missing something here, he did ask a question about THE STEERING RACK AND PINION UNIT correct?
Old 01-25-2005, 09:51 AM
AGENT 86
AGENT 86's Avatar
No big deal. Be sure to remove sway bar and have the proper tube wrenches. I switched to a Z51 rack since there was no differece in price. Did my own toe in with a tape measure.
Old 01-25-2005, 10:25 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
I've had mine out 2 different times, first for poly bushings, then for a boot that split, yeah I know, why didn't I change it while it was out the first time. But wait, it gets better. I bought the boot from Autozone which was a universal fit and guess what, it lasted about 3 weeks before splitting. The worst part of this job is getting the lines for the power steering off the rack unit. The passenger side mount is a little hard to get the bolts out but other than that it's not a hard job at all. Definitely take the sway bar out first and either do your own aligning if you can or get it close and take it to a shop for alignment. By the way, the last boot change I did with the rack still in the car.
Old 01-28-2005, 11:56 PM
Dr. Evil
Dr. Evil's Avatar
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
I've done a half dozen or so the last year. Its a PITA, especially if it has a power steering cooler.
3.5 labor is about what I charge.
To R & R Rack & Pinion.
Quick Reply: R & R Rack & Pinion.
