Lumbar Question
Lumbar Question
I know I should post in C4 as well and I probably will.
Well, the motors work and the bladders have NO punture at all. I replaced the driver one with some rubber glove part anyway and ...no dice..the seats will not inflate.
What 'cha think?
What 'cha think?
Was the rubber glove material heavy enough? I've used a playtex glove.
Bladder is good? Can you inflate it? Does it hold?
If yes to all above, I'd look for a leak at the air hoses, connectors and valves.
Originally Posted by Mikez40
I think one of your air lines may be cracked. Look them over really good, there is a bunch under there.
Great place to start and if not check this out:
Not sure if this is your problem, but heres the description:
When the motor/pump runs, but the bladder does not inflate, the lumbar repair kit offers huge savings compared to replacing the entire motor/pump. This kit controls the backrest bladder.
Good Luck
Here's the link:
http://www.ecklers.com/product.asp?p...BXPN5VBACJ754E
The seal on the old bladder and the new makeshift bladder are tight. I guess I gotta go into the lines etc. It really isn't a big deal for something I rarely use..but it is just something to fix to make the car more perfect.
Ok - you're using incorrect terminology. The bladder is the device that holds the air in the lumbar portion of the seat. The diaphragm is the rubber piece that is moved by the motor when you press the button on the seat, and pumps air into the system to inflate the bladders. Are you talking about a faulty bladder or diaphragm? If you're talking about patched diaphragms, I'd take them off the car, and redo them in a good quality rubber glove material (ones used for washing dishes) - this will ensure that they are actually air-tight. Once you've done this, if the bladders still don't inflate (unlikely), then you have a leak in the bladder itself, and you need to remove the whole system to find the leak - pump them up, and dunk them in water (bath-tub) - patch the leak, and re-install.
