Timing on a LT5
Timing on a LT5
They mention on the LT5 build video that it is possible to be 360 degrees out of time how is this possible if the cam pin holes and crank locator line up?
Yes, it's possible. In fact, someone that will remain nameless timed one bank of cams 360 out when doing a little work on my car. The reason that it is possible is because a 4 stroke engine's crank turns 720 degrees to complete the valve events.
It was not Corey, BTW.
Ime confused by this,how is it possible if the pins are in and the crank locator is in ,ime aware that the crank turns 1 rev to the cams two,is there a way of checking?,thanks
The four strokes of the cycle are intake (Down), compression(up), power(Down), and exhaust(up). Each corresponds to one full stroke of the piston, therefore the complete cycle requires two revolutions of the crankshaft to complete.
make sure you check which valve open intake or exhaust to find position.
Joseph
Originally Posted by ZR-the one
Easy , It take 2 (360)degrees to make a full cycle on a four stroke engine
Joseph
Joseph
Thanks.
You really don't have anything to worry about because when you time all four cams simultaneously with the crank pinned, you can't screw this up. It's only if you pulled the crank pin, move the crank and decided to pull the cams on one side that you would potentially have a problem with the phasing of the cams.
As long as the crank is pinned and all the timing holes on the cams line up, you are fine.
Actually the crank turns 2 rev to the cams 1.
Yep thanks for correcting me on the cam/crank revs,so with the Crank locator all the way home and the 4 cam pins home she should be timed right,and in reality it is only possible to time one bank 360 degrees out?
Thanks for your patience.
Fantastic,i was double checking as the quote in the video has been at the back of my mind.
Does this mean the spark is only delivered every other crank revolution?
spark is provided every revolution of the crank, this is why the sytem is called "waste spark", because you have spark in the cyl. in the exhaust stroke too, this is due to the system design of double tower coils, each time a coil is triggered it sends 2 sparks, one going to a cyl. in the compression stroke and the other going to a cyl. in the exhaust stroke in the opposite bank (waste spark).
Cliff, if you have the crank locator full in it could be either the compression or the exhaust stroke depending on the cam positions, is really when you position the cams and pin them when you are is determining that it will be the compression stroke.
I don't know if I have explained it correctly... plain and easy: pin everything down and it is OK.
I wasnt sure if i had fitted the cams on which revolution ,but i can see that once all 5 holes(4 cam pins and crank locator) are lined up then the groove on the left exhaust cam tells the ECU via the cam sensor where the cams are and determines the stroke on the crank ,motor timed.
I can see the problem on one bank being 360 degrees out,this is when you remove one side of cams after aligning the 2 cam holes and also with crank locator in,then for some reason taking out crank locator and only turning the motor 360 degrees ,then installing the 2 cams,you would effectively put this pair of cams 360 degrees out with the other cams and crank ,the basic thing to remember is to rotate the engine 720 degrees for a complete turn ,is this true.
YES......since I am now timing my LT5. If you think all LT5s were timed 5 years ago and end of story...then you are correct it was not necessary
Actually, I am timing my LT5 using a timing wheel rather than crankshaft locator and dial gauge on the lifter rather than pinning the camshafts....so it has gotton a bit more complicated than just the timing discussed in the 5 year old thread using pins
My camshafts were removed completely so yes you have to make sure which camshaft goes where by the camshaft marks and make sure all camshafts are on the same stroke.
For some like yourself ........everything might be obvious
"Exactly" was referring to specific technical points made by RatRacer and JordiZR1
I should have just "Bumped" it
