Shifter rattle
NCM Lifetime # 982
Shifter rattle
Shifter rattle is getting annoying. It is the reverse lockou lever. Is there a soultion ? TIA
Location: No more yankee my wankee, the Donger is tired!
1 Post
Re: Shifter rattle (FrankUrbinati)
Check to make sure you have the set screw. It'll be in the back side. I'm missing mine and that is what rattles on mine.
Re: Shifter rattle (Jeffvette)
Jeff's right. Snug up the screw, maybe about once a year of so, and you'll be fine. Don't overtighten, but you will need to repeat it. I am going to retighten mine mext weekend, I did it last in 1999.
Hope this helps.
Hope this helps.
NCM Lifetime # 982
Re: Shifter rattle (ZR1991)
Too late the previous owner stripped the set screw.
You can buy that lockout ring itself from the dealer. However, if you put in a Hurst shifter, it'll get rid of that whole mechanism. The internal spring detent combined with the reduced lateral throw makes the shifter feel like the '95-6 passive lockout. Plus, you'll love driving the car a lot more with this shifter- solid, precise, smooth, and more reasonable in its throw.
I got'em for sale, email if you want one.
Chris
http://www.prism.gatech.edu/~gt1479b/hurst.jpg
[Modified by zrchris, 5:54 PM 9/5/2001]
[Modified by zrchris, 6:27 PM 10/10/2001]
Chris
