Headers on Craigslist
Guys:
Set of Lt5 headers on Craigslist, $750
http://sacramento.craigslist.org/pts/273580141.html
Not mine, not the seller, don't know the seller, but is local to me and I can check them out.
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Received 3,043 Likes
St. Jude Donor '05
I may be interested...Can I block off the EGR? Wonder how hard it would be to add smog tubes?
How far is the guy away from L.A.?
The big problem is that even with the air tubes they still won't have CARB certification. You'd have to go to a referee for your next smog.
They're in Shingle Springs approximately 35 miles east of Sacramento. That's roughly 8 hours from LA.
Shipping shouldn't be that expensive, after all they don't weigh that much.
TomC
'90ZR1 #792
St. Jude Donor '05
Hmm, I have some stock manifolds wioh the rails on them..Maybe I could cut these off and reuse them? .I could have them coated black I guess. Dont see how the ref could refuse me if I had tubes and cats...Left the guy a message. If you wind up checking them, Ill pay ya for your time. Keep you posted depending on his response.
I have to smog it at summers end, so Ill wait til after that to install them.
I'd be willing to bet that the injector tubes are standard GM, so any injectors tubes from any GM could probably be made to work.
Having just had my '90 ZR1 smogged two days ago I can tell you without a doubt that they look for headers. I asked the smog guy (who owns a '91 ZR1) how thoroughly they check and he said that they absolutely have to make sure. He said that headers HAVE to have the CARB Approved ID plate.
Period.
Since the '90-91's cats are part of the manifold and No Longer Available from GM, and since it's technically illegal to buy a used catalytic converter, you can get a referee to pass them as long as all the smog equipment works. That still does not make it easy or cheap. Be prepared to spend some time getting the SMOG ***** to agree with you.
I'll be seeing the guy on Thursday, I'll have him bring the headers if he still has them. I'm buying some other stuff from him, so I'll see what else he's got.
TomC
'90ZR1 #792
St. Jude Donor '05
If I get em Ill just get some 3" magnaflow cats, they flow well and are cheap.
Anyone know where I can get a nice (hopefully new/near new) set of smog tubes so I dont cut my manifolds up?
