ZR-1 Won't start
I went through all of these problems with my ZR-1 and did everything that has been recommended here and then some (it is very embarassing to have to push start your car at the gas station or the track!). I bypassed the clutch switch and even added a relay into the starter circuit that would allow more power to get to the solenoid. I tried a different key to make sure it wasn't VATS related. Even after all of this I still had the same problem. The final change I made was a new battery even though mine semed to be fine. The battery was the culprit, as I never had the problem again. Keep in mind the battery still tested out as adequate but it apparently wasn't adequate enough to get the car started on a consistent basis (the no-start was only after driving the car for a while, never at initial cold start). After going through the process I went through, I would first try a new battery before bypassing anything, especially if you are able to bump-start the car. Good luck!
Battery condition
I've always thought that the symptoms with the "no start" on our cars is "TYPICAL" for all vehicles with Nippondenso cranking systems. The solenoid/switch contacts aren't what you would call "severe duty". It takes as I mentioned in my first post "all of a good" battery to crank in any situation other than "cold start" with a cranking motor with mileage maybe 35K, 40K or more.
Quality cables, keeping the grounds and terminations clean and serviced I'm sure improve the cranking but it really gets down to battery condition and the condition of the cranking motor.
Never, ever try to jump in a ZR-1 while trying to push start it. The combination of the wide rear tires, with the proximity of the tire to the door, combined with the difficulty getting in, it is very easy to receive a very serious injury by running over your foot......ask me how I know?
Best thing to do is get a friend (or brother of the beast, as it were) to push the car while you ride!!!
Makes me wonder since you just bought it if the washed the engine we If you can wait since im knee deep in my own ZR1 you can bring the car over and we can look at it next week
Im going to be busy every day but Ill be happy to direct you on how to pull the plenum and we can check the starter take it to auto zone and test it, I have a spare starter that we can check as well and install it and you can replace my spare or we can order one and install it.
Again this week is busy and I have the Ball on sunday ill give you a shout.
Ill be home soon im at work right now ill give you a buzz
Sounds like you are having the voltage drop problem. You might try a new battery, although I did, and still have the problem. I'm gonna go for the big *** wires, next.
#33
#37
After chasing down my no-start problem for years and doing all of the customary changes, battery, starter, VATS, clutch switch bypass, my problem was finally solved with the above solution.
#39
#40
No problem, glad to help.
It's been nearly 2 years since I made my mod and I've *never* had another DREADED NO-START.
I really hated like he!! to cut wires, but at the end of the day it's better to have a car that you can drive than to have a garage queen that you can't trust.
