Just looked at tire selection
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What is the benefit of having matched sets? They are already different widths, seeing different contact pressure, and serving different purposes. I don't see the significance of the tread pattern.
I would think as long as the compound is the same, any tires with similar tread design will do the job.
Location: No more yankee my wankee, the Donger is tired!
1 Post
But you're assuming they'll handle the same despite the differences I listed. I think the actual tread pattern is meaningless. I mean, look at how many tread patterns are out there. There's a few different components, block size, siping, and water channels. They're trying to make the tread patterns look "pretty" for godssake. Maybe they should make the brake pads look pretty too while they're at it.
They look very cool on a stock wheel that's been widened.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'19, '21-'22-'23-'24
Hi Bob and thanks for sharing your knowledge!
I'm new so I proly didn't express my concerns correctly....for this I apologize!:o
I was being concerned about the tire's side wall hitting/rubbing anything on the suspension and or brake lines.
I didn't even think about making a standard ZR-1 rear wheel an inch wider....didn't know that was possible...I'll bet that'll cost!:o
I guess I'm trying to figure out if going up to 18" wheels or an 18 & 19 combo is the better way to go to have a better shot at long term tire supplies.
Thank you for your input!
Tom
Tom
I'm saying a 315 GSD3 on the back of a ZR1 will have different characterstics than a 275 GSD3 up front.
Nevermind. You'd obviously rather assume I'm stupid than think about what I said. Sorry I interrupted your wine and cheese session about tire selection.
#34
Tom
Tom
I suspect it really wouldn't be much wider at all, as the sidewall will bend a bit and take up some of the slack. Unless you have things very close to the tire, I wouldn't think clearance would be an issue at all.
Thank you!! Do you know how long we've been waiting to for you to say "sorry"?
#35
He also said the front and rears serve different purposes...so let's say the fronts provide traction between the car and road, I guess that means the rears don't. No wonder we keep going around and around with this guy. Stupidest post I've read here in a while...this guy just likes to come in here and yank our chain with stupid **** and then hurl insults when confronted. I wasn't going to say anything to him about his first post because it was so stupid and this is exactly what he wants...attention.
I wish the moderators would ban him from the ZR1 section. Everybody makes us happy when they come through here...some when they come in and others when they leave.
#36
Since my father is in the wholesale tire distributorship business, I asked him tonight to make some inquiry with his Goodyear Rep among others and see what the deal is with productivity.
#37
#39
I'll question anyone that doesn't think for themselves. I figured this was a forum and people were interested in thinking/learning/discussing. But instead we're expected to just pat each other on the back and agree with each other on everything?
The only one I insulted was Jeffvette, and that was in response to his insulting post. Read my first post that you say was so clear and then read his response about PepBoy Futuras.
I had said nothing about brake bias in this thread. Changing tire widths has no effect on brake bias. Even pouring motor oil on the front tires does not affect brake bias. It's a property of the brake component sizing. Now, GM could tune the brake bias differently to take advantage of any added braking potential from different tire options, but they didn't. Those parts are exactly the same for ZR1s and base model J55s.
Yes, the front and rear tires do serve different purposes because they get loaded differently. Lateral G's, acceleration/braking forces, slip angle, and footprint are all different front vs. rear. Which was my entire point of questioning Jeffvette's gripe.
So everything you just wrote was wrong, yet you call me stupid? I think anyone blindly assuming they have only two choices for tires is stupid.
Originally Posted by glass slipper
A couple of months ago, he wouldn't recognize the difference in tire sizes affecting brake bias...now he makes a big deal of it.
#40
Since you seem inclined to have this discussion that no one else seems to care about, and the thread has mostly run its course, why not.
So, how many tire manufacturers have you talked to that recommended mixing and matching their different tires front and rear? How many OEMs have done this on new cars? How many race teams run different brands of tires front to rear?
You throw out your think-piece on slip angles and rubber compounds, but where is the real world application? Or are you so far on the leading edge, that no one has caught up to you yet?
There are two street tires made in the OEM size for the rear. Therefore assuming there are two choices for OEM sized tires is not stupid. But no one is saying those are the only choices, read the thread, people are talking about what other sizes can be put on the wheel, like 335/35-17's. So it looks to me like everyone here realizes there are more than just the two choices if they are willing to go outside what was OEM.
