90-91 vs. 92-95 B&B exhaust
What is the difference in the two, the connection on the left? Would it be hard to adapt by a muffler shop putting the 92-95 on a 91?
'90 - '91
'90 & '91 models had a short slipfit adapter over the RH convertor/exh pipe that was maybe 3" long that adapted it to the inlet pipe which was a three bolt flange on the OE system. B&B I believe do their inlet pipe for the right to duplicate the three bolt flange. If you remove the short slipfit the later pipes will slip over the convertor/exh pipe on the right side I believe. I would maybe confirm that with B&B but it seems to make sense.
Corsa makes only one system "all years" and it slipfits on the right side over the convertor/exh pipe on the '90 & '91 models as well as the '92 +. You just remove the slipfit! The Corsa on my '90 was removed from a '95, fitment was no problem.
If I were buying a system I would buy the "later" product, it should certainly help resale if it were necessary!
If I were buying a system I would buy the "later" product, it should certainly help resale if it were necassary!
