Bought another ZR-1!!
Full Power/no LED
That makes sense really if the PROM is programmed to default to "FULL POWER".
It just doesn't know enough to let you see what "it's done"! But you do "feel it"! The momentary action of the switch in this case is only activating the LED, the primary function of the switch has been "deactivated". I could be wrong as hell but it seems likely.
Your '91 PROM doesn't have the "DEFAULT" programmed into it I suspect. Most don't I believe.
