Stereo help................
Ive asked this in the audio section and got nothing so Ill ask it here.Ive got to send the stereo controler out to have it repaired and cant see it.The car is apart,looking up into the dash I cant find it.Ive had this car for a week and its completely torn apart,not too happy right now
remove the passenger side lower dash hush panel.. it is in the dash there a silver box it will have the antenna lead going into it.. it is also near the cruise control module
Ive looked up into this hole and I see a rats nest.I could always follow the antenna lead into the dash.Ive got the seat out of the car,laying in the floor there isnt alot of room here,Ill just keep looking.
The best I recall on my '90 the receiver was above a bracket that needed to be removed to get to it. There were two nuts (1) left and (1) right on a bracket that is maybe 4" wide, 7" long and might have had a curved corner towards the passenger compartment.
See if this link will help you. It's pretty much the "appearance"!
http://www.carstereohelp.com/images/...eCDM91102x.gif
Here's another image that isn't near as complicated. It's right where you're looking you just need to get the bracket #12 in this illustration out of the way!
http://www.corvetteradios.com/home/90TO92.gif
Chris,
NO...NO...NO
The car is a '91 and it's where I've directed him to! He's for sure in the correct area, under right most side of dash. Late(very) '93 and later it's in the storage compartment. I've never seen a '93 in the storage area but I hear that there are cars out there!
Chris,
NO...NO...NO
NO...NO...NO
I found the box,couldnt see it because of the flat bracket.Now,will this bracket move far enough out of the way to get the controller out?I can honestly say that this has got to be the biggest BULL$HIT job Ive ever worked on.Thanks for all the help here guys.
I believe there's only the two nuts holding the bracket and the receiver module. Remove the nuts and the harness connectors to the receiver, the antenna and you're likely to have it in your hands and on the floor. I believe there's connectors on both sides of the box.
You've nearly "got it"!!!
I finelly got this basterd out.Theres a question I should have asked in the begining,does this system really work all that great?Off to Dr.Dons it goes.
I got the car back together,what a nightmare.Somebody needs to make this a challenge on Survivor.Now,is it possible to upgrade just the speakers?..................OH,as an added bonus,I just found out the CD player doesn't work.
I'm glad to see that Murphys Law isn't restricted to just my garage.
NCM Lifetime # 982
Send the receiver , head unit and all the speakers to Dr. Dons.
