C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Wanted: Input for New Corvette Garage/Shop
Old 01-18-2008, 04:36 PM
A26B
A26B's Avatar
Default Wanted: Input for New Corvette Garage/Shop
When I thought about who to ask about cool & functional advice for a new garage/shop building that I'm going to build here at home, my first thought was "everyone!" Who would know better than you guys.
Here's the basic floor plan.
It's wood framed, sheetrocked, 12 ft walls, cathedral ceiling under 10/12 pitch, clear span roof. It will have a load bearing storage loft over the "trailer bay." I have the following stuff that will go in the new shop;
4 post lift
Macsimizer class IIM superstation tool box
custom built, 8' x 3' steel shop table
3 engine stands
cherry-picker engine hoist
54 drawer bolt bin
refrigerator/freezer
TIG welder
drill press
I'm particularly interested in how to finish the floor so it will look great, be easy to clean spills, impervious to gasoline & other automotive type fluids.
I plan to decorate the shop with show plaques, neat pictures, banners, posters and parts like the LT5 cam cover Jeff did for me.
Thanks to everyone for all of your input!
Old 01-18-2008, 05:33 PM
A1990
A1990's Avatar
Jerry, some interesting stuff here: http://corvetteactioncenter.com/foru...d.php?t=100923
Old 01-18-2008, 06:55 PM
A26B
A26B's Avatar
Thanks Dennis!! I didn't know about that, appreciate it.
See you in BG again this year??
Old 01-18-2008, 08:06 PM
wildanblue
wildanblue's Avatar
I'm not positive but I think Jeff posted a pic a couple years ago of his speedo @ 198 mph. A blow up of that on the wall would be pretty cool.
Old 01-18-2008, 10:24 PM
C1ANDZR1
C1ANDZR1's Avatar
Being in the electrical business, I just had my guys wire my shop a couple of weeks ago so I know what you are going through. First, put in plenty of electrical receptacles! I even have a couple of reel receptacle/lights hanging from the ceiling. You will not believe how much you use them, especally when you are under a car on your lift. Also, a 230V plug on each wall for your welder so you don't have to have such a long cord, and finally, do not scrimp on the lighting! If you think you have enough, put a couple more! My shop is 40'X50" and I put 16 of those 8' T8 flourescent (small bulb) fixtures in and it looks great. It is much easier to do electrical work when the building is built rather than retrofitting because you forgot something later. Sorry for the long post, maybe this helps.
Jason
Old 01-18-2008, 10:33 PM
A26B
A26B's Avatar
Jason,
Great info. I have 20 of the same light fixtures in my 40 x 50, but never considered the extra 220v welder outlets...great suggestion. I was going to put a couple of air hose reels in but for some reason, never thought about the light cord reels. I have 115v outlets every 10ft with extra by workbench. Thanks for the ideas.
Old 01-18-2008, 10:42 PM
bldavis11
bldavis11's Avatar
Where's the sink?
Old 01-18-2008, 11:55 PM
A26B
A26B's Avatar
Originally Posted by bldavis11
Where's the sink?
The one in the bathroom will be a deep stainless.
Old 01-19-2008, 12:15 AM
Trizney
Trizney's Avatar
Why a 4 post lift?
I have never used anything other then 2 posts, and I don't ever see using anything other.
Only time I see using a 4 post is for an alignment machine.
just wondering??
Old 01-19-2008, 02:13 AM
A26B
A26B's Avatar
Originally Posted by Trizney
Why a 4 post lift?
just wondering??
I bought it originally to be able to park another Vette underneath in the same stall of my garage. Works fine for me & don't plan to buy another.
Old 01-19-2008, 02:57 AM
HAWAIIZR-1
HAWAIIZR-1's Avatar
Wow, looks great to me; "Lifestyles of the Rich and Famous". I'm just a poor guy struggling in Hawaii.
Old 01-19-2008, 07:44 AM
IowaZR1
IowaZR1's Avatar
I can't really make out your dimensions but having pulling a trailer alot and backing into a confinned space can try your patience, I'd make that door as wide as possible. I'd also put a window looking out into the garage area from your office and another sliding door up front between the trailer storage and garage. Any thoughts on creature comforts aka as heating and a/c? I put all my ductwork above my ceiling. And the side exit door unless your house was on that side I would move it to the front.
Old 01-19-2008, 08:31 AM
Rkreigh
Rkreigh's Avatar
dave bright is a dealer for the flooring systems, you might get in touch with him and ask advice.
I also like the epoxy coat with the sprinkles in it for traction.
it's an economical alternative for a big garage.
the one thing I have that doesn't fit your current design but I really like is I have a garage door at the back so I can "pull through" and stash cars in the back yard behind the fence.
very handy for getting yard work done too.
great setup jerry, looks good!
Old 01-19-2008, 10:23 AM
A26B
A26B's Avatar
Originally Posted by IowaZR1
I can't really make out your dimensions but having pulling a trailer alot and backing into a confined space can try your patience, I'd make that door as wide as possible.
The door is 12' wide.
The office/garage window would be great except I have tools all along that wall on the garage side. Can't figure out a better place to put them. Maybe I can put the window higher than normal, but would require standing to see out. Better than nothing?
Yep! will have HVAC. The central unit sits in the loft area & ducting will be exposed due to cathedral ceiling.
You got it....house is on the side where the door is.
Old 01-19-2008, 10:24 AM
81c3
81c3's Avatar
Make sure you get a good parts cleaning machine/sink like one from Zep or Saftey-Kleen. I wish I had one many times....I use a pan, with solvent in it and a parts cleaning brush
Are you running hard air lines on the walls, or just a compressor & a soft hose? I use the latter set-up, which works, but having the lines run around the shop with nipples is more convienent and is more professional.
Old 01-19-2008, 10:25 AM
A26B
A26B's Avatar
While you're on the beach, some of the rest of us have snow & ice and 105+ heat.
Old 01-19-2008, 10:31 AM
A26B
A26B's Avatar
You work on dirty cars?? Great idea, hadn't thought of that yet. Will do!
The plan is to put the compressor in the top left corner of the trailer bay with a folding wall for more noise supression. Hard lines will be run to two hose reels, one on each side of the bay area.
Thanks!!
To Wanted: Input for New Corvette Garage/Shop
Old 01-19-2008, 10:34 AM
A1990
A1990's Avatar
Yes sir
Old 01-19-2008, 11:12 AM
DMark
DMark's Avatar
Great plan - A Real "MAN CAVE."
Only addition should be a pullout sofa & hotplate for when the wife puts you in the Dog House.
Old 01-22-2008, 02:01 PM
Triple White 92
Triple White 92's Avatar
On the garage/shop side, I would get rid of the traditional garage door opener and put in a jack shaft opener. This mounts on the wall next to the door and uses the spring shaft to open the door. Depending on the angle of your ceiling, you can route the door in a more vertical direction instead of into your garage. It give you more space to place your 4 post lift with the opener out of the way. That is what I did in my garage addition and I love it. The opener is twice the price of a standard opener but worth it in my opinion.
Mike Boggs
92 C4 Convert.
97 C5 Coupe
Quick Reply: Wanted: Input for New Corvette Garage/Shop
