Finally.....
cadillac531,
You have given me some much needed inspiration to clean-up and detail my '94. I'm a new ZR-1 owner. The only thing I had reservations about when I bought mine was a filthy engine and engine bay. I'm working on a '85 and a '78, once I finish them, I hope I can get my LT5 looking as good as yours.
Reading some of the other replies, it sounds like you've given others inspiration also.
Any, after the fact, hints or tips you can share? Anything you would have done differently to make the job easier?
The one tip I'd have for everyone is to paint the motor first and drive it for a while. Let the grey finish cure, then letter it. The engine enamel requires heat to cure, so if you have any overspray from the lettering it can easily be removed by gently scraping it off with a razor without affecting the grey finish. Just don't fire the motor until you have cleaned any and all overspray. Once the motor heats up and cures the letter paint, it is permanent.
Other than that, I don't think there would be anything I would do differently. The most difficult part of this task is masking everything off. Other than that, it's a walk in the park.
Hope some of that helps.
Constantine
How many hours did it take you?
I bought 2 cans of the Lingenfelter paint 3 years ago, this just got bumped up on my to do list
I think, overall, the project took about 4 hours to paint ( 3 hours and 55 minutes to tape and 5 minutes to paint ) and another 1 hour or so to letter.
Thanks.
Constantine
cadillac531,
Yeah, you really should take this on, if your factory finish is pitting. The LT5 is striking no matter what, but after you refinish it; you pretty much never want to have the hood shut. There are times when I park it in the garage that I leave the hood open, so when I walk past it I can look at it.
#34
There was a lot of reminiscing about the past LV events, especially the
Nellis mile. We would surely like to do that again, Lt. Col. Ron H. (Ret).
Are we going to have another ZR-1 West Gathering in Las Vegas?
ZR-1 ers seem to need some kind of racing event to get them together.
As for my car: runs great, don't get to drive it enough, any more mods would be mucho $$$ at this point.
C ya and say hi to the missus.
Ted
#35
Powder coat vs. spray...
Taking his word, I experimented with high temp wheel paint and high temp clear. I experimented with the plenum...
I liked it so well, that I went ahead and sprayed the cam covers (work in progress). Note: In the photo, the finish almost looks grainy. Not so to the eye, but to the camera in closeup mode, it does. To the eye it looks quite nice, methinks.
I haven't decided if I'm going to mask the lettering and spray it, or hand paint it. Both have their drawbacks, I find.
The paint is high temp Dupli-Color. LGAFF suggests another maker for the paint as being superior to the DC, and I would have taken his advice (has quite a bit more experience w/ paint and heat). But, it was a case of coulda-shoulda-woulda. The plenum did not yellow with heat, so maybe the high temp wheel paint will be OK. Time will tell.
P.
P.
#36
I had the same question when Marc H switched from powder coating to spray. He told me that in his experience the powder coating is brittle and tends to crack and chip around the bolts, sometimes. He also had trouble with the clear turning yellow - perhaps just the wrong choice for the clear.
P.
P.
Clint aka billybaloneey
#37
It wasn't all that bad to tape off. I ran tape over the top of the letters/numbers, pressing down to show the border of the numeral and cut out them out with an x-acto knife.
As far as prepping, I made sure the surface was clean of any debris or oil and sprayed the paint. There were no issues with lifting or bubbling.
I masked the engine as you did but as for the lettering I free handed.
Looks gorgeous!
#38
if the black on the lettering is in good shape and you don't want to repaint take some clay and "pack it" into the lettering and then peel it out when done you can then take a fine brush and touch it up
I just thought of this and it should work
get some precut some "circles of tape" to mask the bolts
I'd drain the coolant and remove the lines
sure beats taking everything apart, looks awesome
my engine has all the fancy signatures, but as soon as they fade away I'm going to try and repaint it in the car as you have shown.
pulling those cam coves is a chore and often the bolts have siezed and break
#39
