LT5 Stage III cams for sale (new)
#41
I have a set of these exhaust cams, going to put them on the intake side and run a milder set of exhaust cams
#45
That is awesome . I am still in my mid 20s so I have been brought up around the LS1/2. Do you know what all mods he had on his? That MPH is seriously quick.
#46
his tuning, cams, head porting, and tuning skills are amazing
he's running quicker and with the same MPH as most of the high end strokers
I was THRILLED to get 129 trap speed and that's with a 390 LPE with "full boogie" treatment
I suspect pete's heads flow way better and he certainly is a much better driver than I'll ever be.
my bet is that he's also over 500 at the tire by now. I make 508 to run that same MPH
#47
Pete is really getting alot out of that stock block engine
His car also weighs a bit less.
#48
So, what's he done to lose the weight?
That's a phenomenal setup. Somebody should do a write up on how he has accomplished this, that is if he doesn't mind divulging his secrets.
Damn, I'm a full second, and 12mph slower with the same shortblock. What a great motor this is. Twenty years later, and guys are STILL tweaking more power from it.
#49
Here's the car in the flesh from a few years ago. And it still drives like a stock LT-5 albeit w a slightly higher idle and a bit more shake.
This is from the School of Hard Knocks
Sorry can't embed. Don't understand why? Copy/Paste the link below sans brackets.
{http://youtu.be/SFNFOhGGlR4}
#51
Some things are obvious like A/C delete, spare tire etc. Flywheel not only reduces weight by 14lbs, but also rotational mass. Other things, I would have to kill you if I told you. He was running an electric water pump but realized it wasn't worth the gain in parasitic losses vs reliability.
#54
NCM Lifetime # 982
Is that you walking on the Brooklyn bridge with Jon Voit ?
