Anyone need a front suspension cradle in Texas?
I have one out of a '91 ZR-1. It is the cross member that has the motor mount supports and holds the suspension A arms. It is in very good shape. I need it out of my garage. It is free but you have to come get it - I don't want to hassle with shipping it. I'm in Austin.
Anyone know if that part is the same as a normal C4? If it is I'll offer it up in the for sale section after giving you guys a crack at it for a couple days.
Thanks for the feedback guys. I put it in the general F/S section. If I don't get any bites for local I'll consider opening it up for shipping via greyhound for shipping cost + $65 to cover the time. If that doesn't work in the dumpster it goes.
91MG,
Should be stenciled in yellow right across the top of the crossmember area, usually on the side that faces towards the oil pan between the 2 motor mount brackets.
If the motor was a leaker, might be gunked up with dirt and not visible without wiping the grease away...
There is no part number in that area. The salvage yard it came from used something to clean the whole thing - it was very good as almost no grease was on the rest of the suspension. Perhaps that took it off - but there is no grease on it to hide anything.
