Fixture to flow LT5 head out there?
Received 3,043 Likes
St. Jude Donor '05
About to start tearing down a 5k mile LT5 I sold to the guy that bought my Z last yr. Will have a full P&P, externally polished, going to grind the cams etc.
I have never seen a flow sheet on these and may have to make a fixture if I cant find one.
I do want to fully document this before and after to see what the gains truly are at all levels.
Anyone?
Anyone?
St. Jude Donor '05
Thanks not great with the search over there, posted up in tech.
NCM Lifetime # 982
I heard that the inside of that engine was hollow
St. Jude Donor '05
Say it aint so Frankie
St. Jude Donor '05
Sent them both pms
St. Jude Donor '05
Got it polo thanks.
St. Jude Donor '05
Well its set in stone, my car goes out to the body shop next week so in its place will be the motor getting torn down.
Thanks to those who have pmed/offered help.
Its a little irritating that so many are tight lipped about this stuff to be honest. Ill post it up anyway someone has to....its been done a thousand times anyway.
St. Jude Donor '05
I bet few if any even have them...just a hunch
St. Jude Donor '05
What number at what lift, intake, exhaust, etc. Looking for an actual sheet that lists .100 up through .500 or something to that effect.
Anyone?
Anyone?
For 4-valve heads, the .050" lift numbers are relevant. Hopefully, somebody can post up a flow data sheet as I'm curious also. It'd be even better if this thread turned into more than a few pages.
On the JE Piston's, it's their Thermal Barrier on top and Tuff Skirt on the side's
My heads had a budget... stock valves and guides. I shot my $$$ on the bottom end to hold up to N20 shot. I ended up were you are restarting from @ .450 lift
