Power key on miss
St. Jude Donor '06
Power key on miss
When I turned on the power key yesterday the engine would stumble badly and miss at 3000 rpm when the 2nd set of injectors came on especially noticeable in 4th gear
It ran fine with the power key off
I just put a new serpentine tensioner on it but I dont see anything around that like a loose plug I knocked off that would cause that
Does anybody know what this could be?
Check out this post, same problem, lots of discussion on possible causes.
http://forums.corvetteforum.com/c4-z...er-key-on.html
Gentlemen!
Here's how to avoid power key, injectors, miss at 3000rpm, etc... issues my friends!
#1) Power key "ON" all the time!
#2) Pedal under the right foot on the carpet as much as possible
This should help avoid switch and injectors miss behavior!
Martin
PS: Had a vacuum issue on my old mans '90 secondaries a few years ago! Some of the flex tubing run in front of the engine so...?
Martin
St. Jude Donor '06
Gentlemen!
Martin
Martin
You nailed it
When I was putting the tensioner on it is very tight in there and I broke a hard plastic vacuum line that runs from under the front of the plenum to in front of the coolant tank under the pass headlight
BTW would someone please tell me who the douchrocket is who decided that hard plastic vacuum lines were a good idea
You nailed it
As for the tip, my pleasure!
