Wet pax carpet
Wet pax carpet
While this Vette isn't a ZR-1, the systems for ac are similiar to a point. My wife's car is draining condensation into the pax floor carpet making a soaking mess. I know that there is supposed to a drain for that and it gets blocked. I can't find it in the book. How do I fix that as I may need to check my Z for the same thing later. Thanks!
The drain for your windshield well (for better term) is plugged . It's a 1"x 5" black rubber tube with a crimp on the end. It's under the hood on the pass side and is probably plugged with debris.
I think what is happening is your fresh airway (right in front of the windshield and below the mesh) is filling up when it rains or you wash your car. I had this problem on a 95 Vette. You can access the drain by removing the pass side fender panel, and you will see it right under the air box. Check the one on the drivers side too.
As stated you have drains on both side of the car. Pull the panels and start looking. My ac on my 91 drains right behind the front wheel on the passenger side. If the drain is plugged or not attached the condensation will drain from the evaporator suitcase to the passenger footwell. GC
