65 code on ABS/ASR
65 code on ABS/ASR
I went to check out a 1992 Vette for a friend of mine. I checked the codes and found a H65 code for the ABS/ASR. It doesn't show any current codes. The book that I was using shows it to be an adjuster assemblt fault. Any thoughts on what that might have been? Thanks for the help.
It's an error in the adjuster assembly which houses the throttle and cruise control cables (always wondered what that was called) . "Code 65 will set if CKT 1685 or CKT 1686 are shorted to ground, Shorted B+, shorted to each other, or both open at the same time (unplugged?)." Probably not a problem since it is old.
