zr1 emblem - CorvetteForum - Chevrolet Corvette Forum Discussion
C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
zr1 emblem
Old 11-24-2010, 10:20 PM
whichvette
CF Senior Member
whichvette's Avatar
Default zr1 emblem
how do you remove old emblem on rear and replace with new non decal?
whichvette is offline
Old 11-24-2010, 10:47 PM
Goldcylon
Goldcylon's Avatar
Its just stuck on with Double sided tape and two guide pins. Wiggle some thin weedwacker line in there from side to side and do some gentle prying with non maring "Tools"
"new non Decal ok you lost me there"
Goldcylon is offline
2000Spirit
CF Senior Member
2000Spirit's Avatar
The safest and quickest way I can think of is to use dental floss, work it behind the emblem working it back and forth and cut the old adhesive until the emblem comes off.
Next use 3m Adhesive remove to clean off the old adhesive. Then your ready to put on the new emblem.
2000Spirit is offline
Old 11-24-2010, 11:22 PM
ScottC95ZR1
CF Senior Member
ScottC95ZR1's Avatar
All good advice above. I've never removed an emblem but alot of C5 owners remove their Body Side Moldings (BSM) which are fixed to the car with adhesive.
I have read some use fishing line after applying heat. I'd imagine the emblem will come off pretty easily.
ScottC95ZR1 is offline
Old 11-25-2010, 08:40 AM
Vette Daddy
CF Senior Member
Vette Daddy's Avatar
Heat gun or hair dryer will aid in softening up the adhesive. Reach under the bumper and make sure there are not speed nuts attached to the locating pins.
Vette Daddy is offline
Old 11-25-2010, 10:35 AM
rickyrj1
CF Senior Member
rickyrj1's Avatar
heat gun & fishing line works great,
rickyrj1 is offline
Old 11-25-2010, 01:16 PM
Aurora40
CF Senior Member
Aurora40's Avatar
Dental floss also works, it saws through better, but also breaks more easily.
Aurora40 is offline
Old 11-25-2010, 10:37 PM
whichvette
CF Senior Member
whichvette's Avatar
thanks didn't know it was only a sticker with guide pins
Old 12-04-2010, 12:18 PM
whichvette
CF Senior Member
whichvette's Avatar
thanks for the help the orginal colored emblem looks much better then the all black non painted version that was on there
Quick Reply: zr1 emblem
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
