LT5 bolt pattern
Emerging Vendor
Yes they will, but only 5 of the 6 bolts line up.Its not a problem 5 will hold the trans
in place. before you install a700r4 or 4l60e contact petezr1@gmail.com . He makes
an adapter that allows you to install a much stronger 4l80e transmission and allows
you to reuse your 6-speed drive shaft and c-beam. He also has a flexplate.
Ask me how i know, i have broke 3 transmssions in the last 6 years (2 4l60e and
1 700r4 ). they will not hold up to high HP engines for long.
I'am replacing the last trans (700r4 full manul shift) with a 4l80e with his new tail housing.
John Becker
1990 white/black #2546
110,000 plus auto eq. zr-1
FLA. tag AA FC
John Becker
FLA. tag AA FC
