There is NO stock ZR1 going to go 11:50's. Closest one that I know is a white 91 (11:60's) has the top end done , cams retimed, headers , modded exhaust. That car is in central Fla. and the driver is good.
Not here to knock the ZR1. I own 2.
NO stock ZR1 is going to go 11.50's, but that's not what we are talking about is it? It's clear I was referring to a 500hp. car with the top end done. And 11.60's is in the ballpark. (I said "11.50's 'sh"), guess I wasn't clear.
The example you provide proves my point. With the exception of the top end work, nothing on that engine is "modified". Stock pistons, bore, and stroke. I don't consider a modded exhaust a modded engine, but that's debatable.
There are even stock block 350 c.i. old ZR1's in the low elevens. An example is Pete from the Chicago area. But that one is cammed.
