oil cooler lines
6th Gear
oil cooler lines
Hello everyone
I am about to replace the oil cooler lines on my 91 LT5. Looks pretty straight forward..any tips or hints on doing this successfully? Thanks for the help
NCM Lifetime # 982
Have a cup & some rags ready for excess oil out of the oil cooler. This is a good time to change the oil and filter also.
For more info http://www.zr1.net/forum/index.php
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
I took mine to the car wash to get rid of the oil that had seeped into all the hard areas to clean. Have a good wrench available to tighten the new ends...it is a limited area for a wrench to fit at the right angle.
Make sure you get the old o-rings off and you can find them....kind of hard to find them when they fall down in the oil cooler shroud.
Mike
Mike
