Another question... TB coolant plug
I was just ready to drill, tap and plug the coolant port to the TB on my plenum when I saw a thread picturing it done on the injector housing side. Was this done with the injector housing in place? Can I be pointed in the right place to read an article? Thanks!
Not a real good picture, but you can see the brass plug on the left. I wrapped it with Teflon tape before installing it. Someone said it should be aluminum instead of brass to eliminate electrolysis issues. Well, it's been 3 years and no problems yet. But, at some point I may put an aluminum set in there, when I have the plenum off again for any reason.
So far just fine tho. It is a good modification, IMO.
P.
