C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
rear C6 Z06 brakes installed and bling pic's
Old 04-29-2011, 07:42 PM
LT5corsa
1994 Admiral Blue ZZZZZR1
Support Corvetteforum!
LT5corsa's Avatar
Northeast Events Coordinator
Originally Posted by Polo-1
They should fit your rim.
I'll get the exact measurement this weekend for you Matt.
Kevin,
Did you get the snow off your new Z yet?
I know I'm not the only one that wants to see pictures of your "NEW" Z.... Please show us!
David
Old 04-29-2011, 10:32 PM
Polo-1
Polo-1's Avatar
Funny you should ask that......
One can only DREAM...........
We had snow last week. Snow Thursday and cold rain off and on.
Yes, That's Jim's 402... He can't get here from Montana. We have 3 mountain passes between us. They are getting hit with another foot of snow tonight.
Old 04-29-2011, 10:33 PM
Polo-1
Polo-1's Avatar
Old 04-30-2011, 12:46 AM
LT5corsa
LT5corsa's Avatar
OMG.....
Love those new wheels!!!!!!! LMB is "the" color for the Z06
And that motor? Very nice!
David
Old 04-30-2011, 08:36 AM
FU
NCM Lifetime # 982
FU's Avatar
Location: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Originally Posted by LT5corsa
OMG.....
David
Dream on homey !
Old 04-30-2011, 09:35 AM
hiznhrz
hiznhrz's Avatar
Polo-1, I also have a LMB Z06 and I've been thinking about adding the newer model year center console. Would you mind telling me if you bought OE or aftermarket parts and are you happy with the fit/finish? Would you mind telling me the part numbers you had to buy to do the job and where you got them?
Also, did you do anything with the dash pods to the left and right of the speedo?
Thanks.
Old 04-30-2011, 09:53 AM
Polo-1
Polo-1's Avatar
Originally Posted by FU
Dream on homey !
I think with a BIG hood scoop it will fit
Thanks.
Stock GM 2008 center dash. I went through Gene Culley he sells them the cheapest I found. Really good to work with. I was going to do the 09 pod (black dic ) but the 07 gray looks good with just the 08 carbon center added, to me.
Old 04-30-2011, 12:21 PM
hiznhrz
hiznhrz's Avatar
Thanks. By the way, I do wonder sometimes if I made the best choice. Your stroker sure would have looked good under the hood of my 91. It's a beautiful motor and as I remember you built it with the best of everything.
While there is a world of difference between my 91 and the Z06, the thing I enjoy most about the Z06 is the low end torque. When you had your stroker in your 94 ZR1, how would you have compared its seat-of-the-pants performance to your 07 Z06 from launch to 100 mph ?
Old 04-30-2011, 01:19 PM
Polo-1
Polo-1's Avatar
The 402 only had 40 miles on it. Just babied. Most did not know that I flubbed the intake cam on the driver side...... First time cam timing on a quad. Somehow I must have hit the pointer or something. Anyways, It had 210psi on the passenger side and 170psi on the driver side. The motor never sounded right cranking on fire up. After some help from Pete, Marc, Corey.... I had to pull the motor and recheck all the cams. Timed again and all is cranking 210psi. The motor never made it back in the car.
The limited driving I did, was massive torque gain. I live on a hill side, with 40mph limit. The 350 would start in 5th at bottom and I would be down to 3rd by the top of the hill. The 350 would pull 4th but you would be in the throttle pretty deep. The 402 would pull 5th gear, just idle lugging torque. It's much the same torque feel of the 427 LS7. I do love the torque it makes. For those that have not driven one, the car just needs to 900/1000rpms and your good the go in that gear. I think Top Gear did a 5th gear take off with it. Crazy torque.
I have a 380ci LT5 that Im building for GC. I know he will get a big torque gain with the offset ground factory crank. This is why I'm a BIG fan of the 378-382ci LT5. If you are thinking of making a 368 go the extra few buck and make the crank 3.75 stroke.
Old 04-30-2011, 08:52 PM
Polo-1
Polo-1's Avatar
getting back on track here......
You have 1 7/16 from hub and 6 7/8 from center axle out. Check your rims Matt.
Old 04-30-2011, 11:12 PM
rickyrj1
rickyrj1's Avatar
I'm more than happy with the set up. The Z finally looks like it has proper brakes & also performs very well. All GM hardware makes it easy for replacement parts
Old 05-01-2011, 05:47 PM
FastMatt2
FastMatt2's Avatar
Dam I wish I had bought that motor from you!
Old 05-02-2011, 09:41 PM
  #33
Polo-1
Polo-1's Avatar
I guess I could give Jim his money back and say someone has stolen it
It should stop snowing some time soon, right Jim....
Old 05-03-2011, 02:17 PM
  #34
FastMatt2
FastMatt2's Avatar
every time I see that pic I want to hit my self in the head with a hammer....
Old 05-06-2011, 09:43 PM
  #35
COPO
COPO's Avatar
Looks good bro!!
Old 05-06-2011, 09:54 PM
  #36
4DSZR1
4DSZR1's Avatar
Holy crap, that car is Killer looking!
Rick
Old 05-07-2011, 11:00 AM
  #37
Polo-1
Polo-1's Avatar
Thanks Rick
Just keep the hood closed and all is good. GM spend $0.00 dollars on the appearances of the motor.
Old 05-07-2011, 09:52 PM
  #38
shaynezrl
shaynezrl's Avatar
Default c6z06 rear brakes
Those set up looks great. I have been trying to do that set on my car for awhile now. You just gave me inspiration to finish.
Quick Reply: rear C6 Z06 brakes installed and bling pic's
