91 ZR1 bose/gold cd radio
I had my bose unit serviced, i reinstalled and it worked great while on 2 hour trip last fall. Car has been in garage scince then, I go out and start it twice a month. I keep a battery maintainer connected while sitting in garage. Today i started it up and turned on radio, antenna doesnot come up, radio does nothing, cd's and cassette tapes go in like they should, and eject like they should. Radio fuse is good, i dissconnected negative battery for 5 minutes and reconnected battery, but still nothing. Is there another fuse somewhere that i am missing? All help is appreciated.
I was gonna look in the service manual but I don't think it's anything in the car other than the radio itself. It sounds like the on/off of the radio is not working. Two things happen when you turn on the radio. One is the antennae will come up and secondly you will get sound out of the speakers. Whether or not the radio is turned on, you can still insert or eject a CD or cassette.
Ok just noticed that there are two fuses that go to the radio. One is in the main fuse block labeled Radio. The other is in Auxiliary Fuse Block #2 and labeled RDO
Check your CTSY fuse. It controls the antenna relay, as well as the radio amp. It also feeds your a/c control unit, the interior lights and cigarrette lighter. If you notice any of those not working, it is probably
Jimthe CSTY fuse
Jimthe CSTY fuse
