C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
need Tach help
Old 03-27-2011, 12:02 AM
ncChris
ncChris's Avatar
Default need Tach help
The tach on my 91 reads exceptionally high...2200 at idle
and pegs out quickly. This started to happen a few months ago.
Have no idea what to check.. All advice appreciated...Thanks
Chris
Old 03-27-2011, 02:12 AM
mike100
mike100's Avatar
so are you saying the actual rpm is high or just the tach reading.
anyhow, I had a vacuum leak issue when I got mine. would flash to 2000+ rpm when you started it rather than the 1400-1500 it normally does. I had the big hose under the plenum pop out of the purge solenoid along with a little too much PCV valve air contributing to a high idle.
what I did for diagnosis was to take a stiff box and block off the trottle body while it idled. If it doesn't nearly stall, theres a vac leak in there somewhere.
Old 03-27-2011, 08:04 AM
James93LT1
James93LT1's Avatar
http://forums.corvetteforum.com/c4-g...-problems.html
Old 03-27-2011, 12:07 PM
ncChris
ncChris's Avatar
The tach reads too high....The idle is normal while tach reads between 18-2000r. When I get on it the tach passes 8000 r and hits the stop while there's still hard pull.
Old 03-27-2011, 06:28 PM
FASTAZU
FASTAZU's Avatar
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Had the same thing happen with a 90 I had was a bad tach filter.
To need Tach help
Quick Reply: need Tach help
