C4 ZR-1 Discussion General ZR-1 Corvette Discussion, LT5 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
How bad does the car feel without the top?
Old 04-04-2011, 12:47 PM
Z51JEFF
Z51JEFF's Avatar
Originally Posted by VetteMed
I like the idea of the AFSB... I just can't get used to the appearance of it. It's better than the highschool metalshop R-D racing piece, but still very obvious.
I wouldnt own any of these.If the slop in the car topless bothered me that much Id just leave the top on.
Old 04-05-2011, 12:35 AM
902066's Avatar
I like driving with the top out. Have a R+B Targa Truss, it works well [not crazy about the looks]. Really wish G.M. would have gone with an electric moonroof. The car cost $60 thou. new, what's a couple thousand more for a moon roof from the factory?
Old 04-05-2011, 09:37 AM
Graybeard ZR1
Graybeard ZR1's Avatar
Originally Posted by GTB/ZR-1
I'll be going on my 17th year w/ my car in July, and I've never driven it w/ the top off...
Me too George. Seventeen years and I tried it out once. Too much cowl shake and flexibility.
But Nacho, it's good you're playing around with the top, snug those bolts up when it goes back on. Because they have a tendency to become loose over time. Even loose enough to have the top fly off at speed. Don't laugh, it's happened. It's a rare but scary, and expensive occurrence.
Old 04-05-2011, 10:35 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Think an electric sunroof would have been the way to go also.
Of course GM would have wired it somehow into the VATS system.
Old 04-05-2011, 11:08 AM
Peter Mahr
Peter Mahr's Avatar
I like having the roof off occasionally but the car feels much looser. I have even convinced myself that the clear top is not as solid as the painted one. That is probably psychological.
When I put the top back on, I tighten the back bolts first and then the front ones. This settles the top in place and avoids squeaks.
Based on the comments, I am going to get an X brace from a convertible and see how that feels.
Old 04-05-2011, 03:45 PM
dbriana
dbriana's Avatar
Originally Posted by Peter Mahr
I like the look of the Vette2Vette kit but wouldn't it be good and cheaper to get a X member from a convertible and mount that on a coupe like our ZR-1s? I read above that it hangs down a bit so you bottom out sometimes but it can't be too bad if it is stock on convertibles. Would I be able to tell the difference with either solution when the top is in place?
I have the convertible X-brace, it hangs down an inch or two. You can feel a little improvement (20%?)with the top on, with it off it is about 70% of it being on, MUCH better than without the brace.
Old 04-05-2011, 07:54 PM
Peter Mahr
Peter Mahr's Avatar
Good info! Do you have more trouble not bottoming out on speed bumps after you put on the X brace? Did you also use the bolts through the brace to the floor or just at the ends?
Old 04-05-2011, 10:25 PM
Z51JEFF
Z51JEFF's Avatar
I wont put the glass top on the car out of fear it will crack.After I stiffin it up with the Bill B brackets and I see a difference Ill use it more.
Old 04-05-2011, 10:53 PM
Nacho_ZR1
Nacho_ZR1's Avatar
My car came with a glass top but its cracked down the middle. Took the Z out for a loooong drive Saturday night but i must admit.....i was too chicken to take the top off
Old 04-06-2011, 05:32 AM
Rkreigh
Rkreigh's Avatar
anyone try gordons new chassis brace system.
it's light, uses fully stressed steel rods, and it should really help the car
I'm with you all that I don't like the "look" of the frankenstein top brace
but it's stiffer with it on that with the top and I like the targa OFF and the chassis stiff
planting all those ponies without wrestling the car is a good thing
Old 04-06-2011, 08:39 AM
rickyrj1
rickyrj1's Avatar
I have never had my top off but would like to. I'm thinking of picking up one of those targa braces but I think I will have it PC'd krinkled black to match my Brey-Krauss Harness Bar.
Old 04-06-2011, 09:42 AM
-=Jeff=-
-=Jeff=-'s Avatar
Yes it is the same one that vette2vette is selling
I have it on my Z, I have to admit it does feel more solid then before the brace. I am happy with it and I am hoping to get more driving time this year on the car (unless the +$4/gal gas stops me).
only time the top is on is if I am at work and the car is sitting outside or if I get caught in rain. otherwise 90% of the time the roof is off
Old 04-06-2011, 12:55 PM
  #33
dbriana
dbriana's Avatar
It is a little easier to bottom out but not bad if you take it easy on bumps, low clearance, etc. I believe just at the ends, never added anything to the floor. If I remember right the front holes are pre-drilled but had to drill the rear ones.
Old 04-06-2011, 02:51 PM
  #34
LindenBob
LindenBob's Avatar
AFSB Try it you will like it
Old 04-06-2011, 07:55 PM
  #35
VetteMed
VetteMed's Avatar
I dunno, I just can't get used to the look of those contraptions.
Old 04-07-2011, 01:29 AM
  #36
cv67
cv67's Avatar
St. Jude Donor '05
Kinda like braces on teeth lol.
Guess if it helps it helps.
Too bad theres not a way to tie the cowl area in to the front frame rails like welding some tubing with a flange on the upper firewall then tying it into the front frame rails. Maybe a beefier K brace underneath may help reduce flex also.
Old 04-24-2011, 12:22 PM
  #37
anciano
anciano's Avatar
Description doesn't don't describe where/how that thing mounts up. Can you fill me in?
To How bad does the car feel without the top?
Old 04-24-2011, 12:49 PM
  #38
mike100
mike100's Avatar
to the OP...What gears do you run? like 4:30's with lots of traction?- no way I'd ever run without a lid with that much torque multiplication, lol...unless you have more self control than a buhhdist monk or something.
I wish I could have afforded a Z06 because the one thing that isn't as right as it could be on my C6 is the fit of the removable roof panel. What do people like about the targa top? UV and dust intrusion? that seems to be what it does best... I guess I live in the southwest- it's warm all the time and I don't need to overcompensate for the arrival of summer like people who live up north- it's true that 9 out of 10 people like it so GM keeps offereing it despite the engineering compromise.
Old 04-25-2011, 11:40 AM
  #39
5abivt
5abivt's Avatar
I will be buying that vette 2 vette system as soon as my car is back on it's wheels. I saved a pic a while ago of a zr1 in Japan that had a tubular cage style stiffener that connected the cowl to the a-arms and the frame. It looked gorgeous but ivthink it must have been at least 50lbs. I too prefer the roof on for the tightness but I will say the c4 is one if the sexiest bodies with the roof off. With a super stiff suspension (all poly everything, stiffest GM leafs, custom length and valved bilsteins and 32/26 mm swaybars I will say the flex got a lot better. I have a camber brace from r-d for the ewp and that REALLY helped with steering wheel wiggle with the roof out. I have a harness bar in the back that definitely helped a little too.
Old 04-25-2011, 11:23 PM
  #40
jrtoffroad
jrtoffroad's Avatar
You guys crack me up. I can't imagine NEVER taking the top off!
Part of the reason I got a ZR-1 over a z06 was the removable top. The top is almost never on my car. In fact I've even done a few autocrosses with the top off and never had any side effects. I think people blow the chassis flex way out of proportion.
It's just such a better experience with the top off, you gotta try it on a nice warm summer evening.
Quick Reply: How bad does the car feel without the top?
